Results 1 to 5 of 5
Thread: Interesting reading
    How to Degree the LS1 camshaft
    500+ hp 408 build up
    Twin Turbo LS1
    Comp Cams valvetrain configuration
    LS1 Intake comparisons
    FAST Intake upgrade for LS1
    More FAST Intake reading
    Lincoln Tech 12 sec LS1 Camaro part 2
    AFR Heads and Comp cam in a LS1
    427 Cubic Inch LSx buildup
    LS1 comparing three Comp cams
    533 HP LSx
    How-to LS1 cam swap
    How to make 400+ RWHP with an LS1
    Inside the LS7
    More LS7 stuff
    STS turbo F-body install
    More STS turbo F-bodies
    Carbureting the LSx Engine
    Gen IV Displacement on Demand
    F-body LS1 MAF & Headers upgrade
    Wiring the Gen3 engine in a conversion
    6-71 8-71 blower drive kits
    Crate LS2 install
    More LS2 articles
    Another LS1 Carb swap
    HPTuner / Silverado
    Crane valvetrain kit and a really cool valve spring compressor
    Nitrous Express 723 HP install
    Swapping an LS1 into an older vehicle
    SS Silverado vs C1500 comparison
    LS1 Hop ups
    Nitrous controller
    22 HP for $220
    The interchangeable LS1
    427 ci S-15 pickup
    Lingenfelter C1500 buildup
    Fast Intake w/NOS
    NOS F-body vs NOS GTO
    LSx Head Buyers Guide
    Head buyers guide
    AFR's 205CC Heads Gain 37hp On Stock LS1
    The Unauthorized Biography Of GM's Stillborn Gen III V-10
    A procharger blown LS1
    GTO supercharged part 5
    GTO supercharged part 4
    Part I: Procharger Gets Our Project LS1 TA Blown
    How To: Properly Install And Degree An LS1 Cam And Timing Set
    GTO supercharged part 3
    Installing Long Tube headers
    Is the 405 hp claim for real in the C5?
    Inside the LS2 engine
    LS1 Electric water pump install
    4L60E High Performance beef up
    TH200R-4 BUILDUP
    MTI Power buildup - Heads
    MTI power buildup - Block
    Free mods - do not remove MAF screen!!!!
    Nitrous Righteous
    LS2 Dyno Flog
    LS1 block basics
    TURBOS
    TURBOS part 2
    TURBOS part 3
    450ci C5R
    F-body headers and ypipe
    400 hp LS1
    More about the LS1
    LS2 powered Colorado
    May 2004
    Those are some good articles. Thanks for the reading RHB!
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    May 2004
    Have you read the cam guide from LS1Tech that was put together? It has some useful info on camshafts, springs and other stuff.
    97 GMC, 2002 LS6.
    Nope, can't recall reading that one. I may have though. I thought I'd link a few things for the newbies.
    Feb 2005
    Austin, Texas
    Hmm the 408 build is interesting. They made 560hp and 540tq with a low compression 408 with a cam a little bigger than mine but with less cubes and inferior heads. Looks like Im going to get my 500rwhp N/A with the 418
    Good stuff red Ill read all the rest when im bored one day.
