Results 1 to 8 of 8
Thread: were to start???
    Dec 2009
    DIrty south AZ
    were to start???
    my insterment cluster isnt working anymore, also the cruse control. the green turn signal lights work fine but everything else isnt working all the sudden. i think it could maybe be a relay but idk what one or anything... thanks for the help guys
    Built 2 Run! 6XX HP/ 6XX TQ
    Start checking fuses and grounds. I can't imagine the whole thing going out at once.
    Dec 2009
    DIrty south AZ
    well the cluster will go out every now and then. and i tap on it and it will work now its not working at all... about a week ago all the fuses were fine?
    Check All the fuses and grounds.
    Sep 2010
    McPherson KS
    I would also check the connections at the cluster, because it sounds like a connectivity issue if you could tap it and get it working again before. I would look for loose wires or a dirty connection somewhere.
    Dec 2009
    DIrty south AZ
    i checked that big plug in he back and blew it out and sprayed elc cleaner on it. i know my cluster is not working, neather does the cruse control. and also some times the climate contorl wiggs out.... i know its got some weird issue somewere but the fuses look good and the plugs clean?
