Results 1 to 10 of 43
Thread: Higher Stall... Pro's & Con's
    Jan 2011
    Albuquerque, NM
    I have been kicking around the idea of getting a new Torque Converter with a higher stall. I have a nice truck with a fair amount of work has a ton of power but really nothing compared to the 2,800 rpm range and up -- thing is sick at this point. But getting it to that point/bower band is the downer to this thing, especially off a light. I do a fair amount of highway driving as I go hunting all the time.
    I did just as 35's and as far as I know it has 3.73's it previously had 33's and really didn't affect it much, at least to my notice. Not sure I want to do gears or the higher stall, cam is another option I suppose. Thanks for all the help!
    If I did do get a higher stall or gears what are con's and pro's?
    2003 Chevy K1500HD
    315/75R16's
    MSD Wires
    E3 Plugs
    EFI Live Tuned
    Dual Exhaust -- no cats
    Banks Shorty Torque Tubes
    S&B Cold Air
    Shaffers Oil
    A pic just cause I wanna show it, it took me a while to get er this way!
    2003 K1500HD Silverado
    6" Fabtech Lift
    E3 Plugs
    MSD Wires
    S&B Cold Air
    Banks Torque Tubes
    EFI Live Tuned!
    if you want a stall get one, but youre in a 4 door lifted 4x4, taking off is never gonna be your strong point, im usually all about doing the small mods first but seems to me you need more POWA!!!! id be looking into cam kits, possibly an SC or turbo if i was you. Then agian i drive a lowered short wide with nitrous like you said you drive highway alot, turbo or sc is gonna help you out more i would think or doing just a cam with a good mid-high range.
    Jan 2011
    Albuquerque, NM
    Agree'd I am thinking a super charger for sure. But in the mean time before I drop $3k or $4k I am thinking a cam or?...
    6" Fabtech Lift
    E3 Plugs
    MSD Wires
    S&B Cold Air
    Banks Torque Tubes
    EFI Live Tuned!
    Arizona/Utah
    Quote Originally Posted by OCHOA505 View Post
    If you get a cam you will need a TC to match. Keep that in mind.
    Arizona/Utah
    A 2600 stall would be well suited for your uses especially one of the ones from Circle D as you won't lose your towing ability and it will be just awesome to drive.
    That said I like your truck looks nice. My recommendation is lose the shorties(they do very little over stock) and get some long tubes. Get some better gear's in there at least 4.10's, but with 35's you would love 4.56's. Sounds like you are already pretty happy with your truck, but like most lifted trucks on the road gears and a small stall are really going to wake it up.
    Don't get a big cam without a stall to match.
    Jan 2011
    Albuquerque, NM
    So if I get a 2600 and do gears how much will this affect the gas and highway use? I know these things never get killer gas millage but with a tiny 22 gallon tank it needs to be fed often! Don't want to make it like 8 mpg, I get about 12 city and 14 highway. If it is gonna kill that I will just be happy as is.
    Buddy had 4.56 but was also at like 3,000 rpm's on the highway at like 70 (but it was a sick truck) I drive more then most to get to my hunting spots plus I pull a small trailer.
    As far as the headers... When I put the shorty's on it was the first time I put a bolt on accessories and actually felt the difference. I don't know if I would say they don't do much over stocks??
    Also, truck has two pipes down to one muffler and two out. Am I killing this truck with not having two in and out (true dual) it does not have cats. Thanks!
    6" Fabtech Lift
    E3 Plugs
    MSD Wires
    S&B Cold Air
    Banks Torque Tubes
    EFI Live Tuned!
    Arizona/Utah
    The gears will actually help mileage around town and the TC will drop you about 1mpg. The TC may even end up helping since its a job to get those big tires moving.
    On a dyno the shorties can't touch the Long tubes and the sound quality is awesome. Most guys on here just run a y-pipe to single 3''in/out mufflers. The type of muffler makes the bigger difference. Is it straight through or chambered? What brand/model?
    Jan 2011
    Albuquerque, NM
    Sounds like a plan! Anyone have an idea what gears and a TC will run (ball park)? Also a good quality TC and gear manufacutre as I am now pretty excited to do this and will be looking to get this done soon.
    As far as the exhaust I have no idea as this came on it and for the moment sounded good and seemed ok, now I am rethinking that. I would also probably be looking to redo this so any recommendaitons for this would be great.
    Any order of doing this that would be better doubt I can afford to do it in one wack!
    like...
    1.Headers
    2.Gears
    3.TC
    6" Fabtech Lift
    E3 Plugs
    MSD Wires
    S&B Cold Air
    Banks Torque Tubes
    EFI Live Tuned!
    Arizona/Utah
    Okay a circle D TC is 400$.
    a gear swap kit is about 185$
    If you got a complete Trutrac rear locker with gears is about 425$
    Pacesetter LT headers and Y is about 380-450
    Custom 3in. Catback with a magnaflow is about 250-300 at an average shop
    Vette servo is 20$
    Arizona/Utah
    Also no vette servo needed if its an 80e
