Results 1 to 8 of 8
Thread: questions... LOTS!
    Apr 2010
    the us
    Question questions... LOTS!
    96 chevy 1500 single cab long bed 350EFI.
    my buddy is trying to get me to pull my motor and swap it for a 6.0L
    pros and cons of makeing the swap?
    do i have to cut my frame to put a short bed on my truck and if so how much?
    im going to put different gears in my truck. 3:55s or 4:11s? whats the difference?
    leme now what you guys think
    "new jack"
    Quote Originally Posted by itsme View Post
    "new jack"
    Yes you have to cut the frame and there really are to cons to the swap. Gears depend on what tranny you use.
    Racoon Twp., PA
    If doing a short bed, there maybe be more than just cutting involved. Prob will have to clip a foot or so out of the frame before the rear leaf springs an shorten the wheel base.
    2013 CC 5.3
    81 C10 LS1 project
    Wichita Falls, TX
    To be quite honest, since you are planning this much work already, sell the long bed and buy a short bed. It's a bit of a waste(in my opinion) to shorten a longbed when there are so man shortbeds in that model. When it comes to 80's and older, shortening them is a little more practical. I just don't see it practical when there are thousands upon thousands of 88-98 short bed trucks running around. Not to mention you could probably sell the V8 longbed and get enough money to buy a shortbed V6 and do the swap and not be out near as much money and work. Either way you go, it should be a pretty cool project
    Dec 2009
    Quote Originally Posted by lo-lyf View Post
    I'd look for a truck that's already what you want. It would be much easier and cheaper. Then you'd be starting with what you really want and could use your money and effort to make your project even better.
    Quote Originally Posted by tanz45 View Post
    Brake lines, fuel lines, drive shaft...
    Wichita Falls, TX
    And I know where you can buy a '89 shortbed
    2003 SIERRA- 5.3 DD
    1985 SWB C10- slow, future plans- shaved, painted, 6.0/4l80e
    Sallisaw OK
    cutting a long bed to make it a short bed seems like more work then it's worth.
    you only have to cut the frame if you want AC as far as the swap. They do have aftermarket setups that move the ac to the top of the engine but i would recommend against that setup.
    i had one and it has always been a source for problems, especially if you plan on a supercharger.
    without a SC it may be fine but the bolts that hold it in place wear out and it starts to shake a lot. the positive side about them is the turnbuckle style belt tensioner with put the exact amount of tension you want on it.
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
