Is the Walbro GSS340 the right pump for a direct swap in a '91 silverado tank?
Walbro 255 LPH IN TANK GSS340 HIGH PRESSURE FUEL PUMP : eBay Motors (item 310188850724 end time Apr-13-10 22:02:52 PDT)
Thanks
 OBS fan
						OBS fan
Thanks
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						one of many that will work. I get the one for the 87 Buick GrandNational from Racetronix.com
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						Racetronix - G7 Fuel Pump Kit - Kit Configuration Page=
Comes with the GSS340m pump
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						Maybe racetronix appends the M in their numbering system or they just keep using it because people want to see the M on the PN. At least with Racetronix you're guaranteed to get a genuine Walbro pump and not a Chinese knock off.
 OBS fan
						OBS fan
						Yes but Jack or any other Walbro dealers offer any kind of warranty.
Years ago when Walbro's were failing left and right,Jack was quick to tell people they had installed it wrong.
I bought a pump from Jack that was bad out of the box and I was told "sorry,no warranty" after I got the "you installed it wrong" BS.
Please dont take this as a stab at Jack@Racetronix.His wiring upgrades are second to none and IMO,he is the best in the business when it comes to innovative wiring solutions.He just sells crappy fuel pumps with no warranty.
I went with the higher flowing Denso fuel pump that was original equipment on the JDM and USDM 93-97 Supra twin turbo's and havent looked back.I actually had to turn the fuel pressure down as it was up 5psi at idle vs the Walbro!!
You guys can waste your money on a new Walbro every other year,lets hope you get lucky and it fails just cruising around,not at WOT torching pistons and head gaskets.Totally not worth blowing up for the few xtra $$$ the Denso costs vs the Walbro.
The Denso pump is also a much better solution than the old Bosch pumps people use.The Denso has been proven to flow more than any Bosch or Walbro pump.I want to say the Denso is rated at 285lph vs Walbro 255.I have also seen flow charts of the Denso at over 300lph when the intank wiring was upgraded to 12 gauge.
Go Denso and never worry about intank fuel problems again,EVER!
 OBS fan
						OBS fan
						 OBS fan
						OBS fan
						 OBS fan
						OBS fan
						Great. Thanks. I just couldnt figure out which Walbro will go in without any modifications or trouble.
I noticed the pump used in the Racetronix kit is labeled "GSS340M" but google says that pump has been discontinued?
 Paid Off
						Paid Off
						i have an extra one sir with hotwire kit
120 shipped cheaper than racetronix 198 shipped
BNIB its the same one in my LSx swap an Redheartbeat is telling you to buy.
2008 GMC CCSB 6.2/6L80e swap
