Found this article in GMHighTechandPerformance! Complete article is here... 2007 Chevy Trailblazer SS - GM High-Tech Performance Magazine
Move over slowpokes.
2007 Chevy Trailblazer SS - Mover And Shaker
We're not exactly sure what's in the Houston water supply, but we're relatively positive they should bottle it up and sell it as an energy drink. It seems like every month we feature another sick LSx car from this area, almost always in the 9s and almost always one of the fastest in the country. It should come as no surprise then that this is yet another monster, though unlike the other H-town animals-this one has the size to go with its demeanor. Owner Holloway Houston and builder Nick Field of Fastlane Turbo chose a two-wheel-drive Trailblazer SS as the platform to build a single-turbo LSX that runs 9.89 at 142 mph. Did we mention it can pull the front tires, weighs in at over 5,000 pounds, and is the second-fastest Trailblazer SS in the country?
Data File 2007 Chevrolet Trailblazer SSOwner:Holloway Houston
Block:GMPP LSX, 418 cid
Compression ratio:9.0:1
Heads:TrickFlow 225cc, ported by TEA, 2.100 intake and 1.600 exhaust valves
Cam:Custom hydraulic roller
Rocker arms:Roller
Pistons:Wiseco, forged
Rings:Wiseco
Crankshaft:Callies, forged
Rods:Oliver, billet
Throttle body:FAST 90mm
Fuel injectors:160 lb/hr
Fuel pump:Weldon 2025, in-line
Ignition:Stock coil-near-plug, NGK #10
Engine management:Big Stuff 3, tuned by Fastlane Turbo
Power Adder:BorgWarner 82mm
Boost:22 psi
Intercooler:Custom air-to-water
Exhaust system:Kooks long-tube headers, custom turbo-back exhaust, MagnaFlow muffler
Transmission:Powerglide, built by Circle D Specialties
Converter:Circle D, 3500-stall
Driveshaft:Custom 3-inch steel
Front suspension:Fastlane custom coilovers, stock control arms
Rear suspension:BMR adjustable lower control arms, Panhard bar, Fastlane custom coilovers
Rearend:Stock, 4.10 gear, posi
Brakes:Stock front and rear
Wheels:Bogart 17x4.5 front, 16x10 rear
Front tires:M&H 185/55/17
Rear tires:M&H drag radials 275/60/16
Fuel Octane:117
Current mileage:4,050
