Results 1 to 10 of 12
Thread: L92 Head Question
    wtby ct
    L92 Head Question
    so ive been checking junkyards for a set of these heads to go with for my 6.0l swap and i keep seeing the pickups showing up as using these heads also.do any of you guys no this to be true?im searching for 07-08 escalade heads which should be the l92's.and on my searches i keep seeing the trucks also.i dont wanna buy these and have them not be the right ones.
    VJ
    2001 Suburban 1500 5.3 4x4 Lt
    WHATS DONE SO FAR- CAI, 3inch Cat back with flowmaster,2-3 inch drop,rebuilt trans with hd2 transgo,TB Converter,aftermarket trans cooler,Tinted tail lamps,Street
    Scene grille,hids,punched Cats,20 inch incubus wheels,07 front brake upgrade,clear corners
    WHATS IN THE WORKS- 2005 6.0L swap in the works,long tubes,Z06 cam,ls6 yellow springs,e fans,ported throttle body all to come shortly
    Buy new ones, they're not really expensive. For about $600 each you can buy them already ported from GM and flowing 350+ on the intake side. See sdparts.com for more information.
    Round Rock, TX
    +1 on getting new ones....But yes they do come on the trucks too..
    Nov 2006
    Rowlett,Tx
    +2 on new ones, all the new 07+ 6.0's have l92 heads
    the l92 heads are stamped,its a 4 digit number,,ill look on the denali.
    L92's are junk! You can't make any power with them and that's why I use them
    Nov 2006
    Rowlett,Tx
    yea, dont buy l92's......i have ported ones on order
    also, the first gen l92's are 4digit(5364), the ones on the new 6.0's are 3digit(823)
    wichita falls, tx
    Quote Originally Posted by STUNNA View Post
    the number on my l92 heads are 823
    Intro Radicalli's
    Yes, the ones I've seen are 4-digit...at least the ones I looked at...but none were stamped, they al had cast numbers....
    Pre-ported from GMPP is the way to go
