Results 1 to 9 of 9
Thread: Any Suggestions?
    Mar 2004
    ok...my brother in law has a 2004 2500HD Crew Cab 4x4 6.0....4.10 gears..large wheels and tires....we both know its a large truck....and bad highway gears...his gas mileage is horrible...400-500 a month on gas alone...gear swap is an option...hopefully last....trading it in on a smaller one is not due to the truck being so new he'll lose his ass so bad on money that it'll take him longer just to break even than he'll even have the truck........but i told him id check around and see if theres possibly anything that can be done to get some better mileage....anything....he'll sacrifice a little power for it....i knoew you all were the experts...so...any suggestions would be more than helpful...
    2004 Silverado
    Start off with a Nelson tune for gas mileage. Change to synthetics throughout the chassis...oil, tranny and rear end lube. Tune up with platinum plugs. Change the air filter to a K&N type filter. If he has wide tires he will need to change back to tires no wider than stock. Be sure tires are aired up to the maximum listed on the tires. Remove all weight that you can from the truck that isn't necessary including the spare tire. Add a bed cover, even a cheap vinyl topper will redirect the air flow over the tailgate or just remove and store the tailgate. If he has those 200 lbs ranch-hand bumpers, lose them for stock ones. Every pound of weight consumes fuel.
    Mar 2004
    Springfield
    FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
    CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
    OR TO GET ME PERSONALLY CALL: 1-615-943-6514
    2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
    Sep 2003
    Mukilteo, Wa.
    Except the bedcover. Studies show that air is redirected over the entire truck anyways, so MPG will remain the same, even if you add a bedcover.
    '05 Tahoe 2WD 5.3
    Performance Mods: Nelson tune, 4" Volant Exhaust, Dynatech Full Header system, Volant Cold Air Intake, TB Bypass, 305/50R20 Eagle GT IIs
    Appearance Mods: 20x8.5 American Racing Torq-Thrust STs, Billet Emblem, Black Chrome Speed Grille, Removed running boards, door guards, fender caps and badges, and Silverstar lowbeams and fogs
    Cardomain Page> Click
    Apr 2003
    Mansfield, Texas, USA
    You forgot a few key points...
    SLOW DOWN ON THE FREEWAY. You have a 6500lbs+ brick, it's not made to haulass at 85mph. If you need to, get a highway cruiser to do that.
    The truck has donut sized stock tires (~245/75R16) and with the .75:1 OD and a 4.10:1 it'll tach out like crazy even at 70mph. So stick to 65mph max to get some economy from it.
    Now, how large are the tires on it currently? You said they are wider and taller... a 33" AT shouldn't be too bad at all. Should still be well over 2000rpm @ 70mph.
    After that do a few things to make it more efficient. A tune works nicely, intake, some full length headers too. Make it the most efficient it can, but I still stress don't drive so damned fast in it.
    Apr 2003
    Actually, the bedcover will reduce drag.
    http://sitemaker.umich.edu/um.gm.truck/bed_cover
    While taking the tailgate off will reduce weight, it will actually increase drag, just something to think about.
    Andrew
    Andrew
    2001 Silverado 6.0 RCLB - Home Page - 4.8 to 6.0 Swap
    Nelson Tune, Comp Cam XR265HR, Pacesetters, Hotchkis Sways, 3.42, Eaton Posi, Transgo, LS1 Fans, Magnaflow, Eagle 219's 18x9.5, Fold-a-cover
    Mar 2004
    Springfield
    Originally posted by agreif+Oct 13 2004, 09:58 AM--><div class='quotetop'>QUOTE(agreif &#064; Oct 13 2004, 09:58 AM)</div>
    <!--QuoteBegin-boonybouncer
    Andrew [/b]
    I dunno about that ghetto graph, but I do know that when I bought my bedcover it came with a 15% mpg increase guarantee. Now for me that didn&#39;t matter because I drive to fast for it to make a difference but, a buddy of mine bought the same bedcover for his truck and since he is a conservative driver, he told me he was getting a couple more miles to the gallon.
    Just my
    And I also agree with Hitman, Keep your lead foot off the accelerator&#33;
    Try using your big toe instead of the whole foot.
    CONTACT: EPLEY&#39;S TOUCH OF CLASSIC 1-270-843-6892
    Mar 2004
    wow...thanx guys....alot i thought of and theres alot i didnt....thats gonna be a big help...plenty of ideas....and if you have more..keep them comin.....i knew i could count on you guys....i owe ya all one..or a few.....thanks again....
    2004 Silverado
    Apr 2003
    Yup, that&#39;s why I get 15.5 avg with my truck and it&#39;s way undergeared. Freeway in summer is 18.5 (air box on), winter is just shy of 20mpg.
    I just cruise about. I&#39;ll get there at some point anyway...
