Results 1 to 9 of 9
Thread: help with H.I.D's
    Santa Paula, CA
    help with H.I.D's
    so from time to time when i turn my lights on it makes the truck go to "reduced engine power", why is that? does anyone else have this problem? is it my kit. any help is appreciated
    kit is a xentec if that helps
    Quote Originally Posted by sleeper1500 View Post
    Done took 'er down to the Pep Boys an pimped it out.
    03 silverado 5.3L
    H.I.D's, 40 series Flow dumped , CAI, 2in Shackles
    03 Tahoe- C.A.I, magnaflow, h.i.d's...more to come
    I guess you're not the guy I just helped yesterday that PM'd me with the same problem? I have horrible memory sometime. Anyway....move the ballast relay ground straight to the big one on the firewall in front of the driver or straight to the frame. If you are the same guy, let me down easy. If not, hope the guy I did help chimes in.
    San Antonio, Tx
    That was me, thanks for the help.
    Rob
    02' 5.3 ECSB| Nelson 93 Tune | 212/218 Cam | Circle D 3200 | LPP lt's w/ ORY | Volant CAI | Magnaflow | Raceready Cutout | Belltech 2/4 | JL Audio |
    Santa Paula, CA
    ill go easy...im not that guy...relay? i dont have one of them on the ballast
    03 silverado 5.3L
    Metairie, Louisiana
    You have automatic lights? If so use a relay harness. The ballast surges power back through the connections it probably make a sensor go haywire. My shops vette did the same thing.
    AEM Brute Force Intake~PowerAid TB Spacer~Hypertec Programmer~Detroit TruTrac 3.73~Magnaflow 1in2out side exit~06 Tahoe 20's~Reflexxion Steel Cowl Hood~2" Rear Shackles~160 t-stat
    Soon to come:
    LS2 cam~LS6 intake manifold~Pulleys~90mm TB~E-Fans~2-4 drop~SS Spoiler~Front Spoiler~Smoked and haloed tails~Denali headlights with amber halos
    www.aacstyle.com
    ^^^for custom headlights and tailights
    Santa Paula, CA
    will do..thanx for the help
    03 silverado 5.3L
    San Antonio, Tx
    When you get your relay harness make sure your ground is solid, somewhere on the block or frame works perfectly.
    Wichita Falls, TX
    Gah-lee a lot of you dudes are having troubles with the H.I.D.s, I haven't had any trouble yet. I'm using the DDMtuning kit with no relays and they never skip a beat. I say that now and tonight if I drive anywhere they will go haywire.
    I know nothing about HIDs but was able to make a SWAG. Good thing since we brought to light another issue for the OP....the relay.
