Results 1 to 10 of 12
Thread: LS1 cast iron or Alum.
    Ohio
    I am looking to purchase the LS1 engine to swap in my 1994 Z71 and see both iron and alum blocks. Is there any major differences other than price ?
    What is the best setup ?
    Oct 2008
    Houston
    Iron blocks came in the truck and SUV's and weigh about 70lbs more
    than alum. blocks.
    Iron is stronger and cheaper to find
    70lbs weight savings isnt gonna mean much to you in a 4,000lbs truck
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by r.barn View Post
    than alum. blocks.
    Aluminum will take just as much as the cast and the weight is about 140lbs difference...that's why i went with an LS2 block
    Oct 2008
    Houston
    Quote Originally Posted by mean05 View Post
    Anyone got a link to weight difference on iron vs. aluminum.
    I've seen everything from 65-140 lbs difference
    Anyone have a reliable source for what it is ..... for sure ?
    Spiro, Oklahoma
    Heres a link that was posted here earlier this week. the author says the difference is 65 pounds. Thats the answer I got the most when I started shopping around for my engine swap. The only thing I don't like about the aluminum block is that I've heard they can't be over bored much. The same link states that the aluminum block can only be bored .010 over, but I'm assuming thats for the 5.7LS1 block.
    Gen III GM Small Block: Engine Builder
    Quote:
    "These blocks already have a 4.0? bore, so they're the best alternative for the guy who wants a bigger motor for his car as long as he's willing to put up with the additional weight (65 lbs.) of the iron block. The only other way to build a big bore motor with a stock block is to buy one of the new 6.0L aluminum blocks, but that's bound to be real expensive."
    For all intents and purposes, it's damn near 100#, like 97-99#. I weighed my bare 5.3L, and my bare LS2 block, and a junk LS1 block, came pretty close to that.
    As for overbore, the LS2 and LS3 blocks OEM recommended overbore is 0.020", and you can get service pistons if needed. LS1 Blocks are recommended for a max of 0.010 overbore. The 4.8/5.3 Iron block allows the biggest over bore, I know you can at least go to to the 3.898" (aka 99mm) LS1 bore, not sure if you can 0.020 or 0.010 over that like on the aluminum blocks.
    Not sure if this worth mentioning, but there is a very small number of the 5.3L aluminum blocks that are actually LS6 block CASTINGS, with the smaller 96mm cylinder liner. These can be overbored to 5.7L. Again, these are very rare, but they are out there in the LM4 equipped 2004 Rainiers, 2003-2004 Trailblazer EXT, 2003-2004 Envoy XL/XUV's, and 2003-2004 SSR's.
    As for the other iron blocks, I have seen people going 0.060" over, not sure what is the max-safest overbore. OEM calls out 0.020, but what the aftermarket has been doing seems to be going a little further than that.
    Just reading over the engine builder article revealed lots of incorrect info, but in general it's more correct than it's wrong.
    Mike
    http://kds-performance.com
    Oct 2008
    Houston
    Quote Originally Posted by beertestr View Post
    lol
    now have
    65 lbs
    99 lbs
    170 lbs
    Personally 100 lbs "sounds" about right. Thought 65 sounded low, but
    thought 170 was high too.
    For as cheap as you can get iron truck blocks for I just dont see paying
    extra for the aluminum. Maybe in a drag car where you're counting 10th's
    but dont see the difference in a 5,000 lbs truck.
    Feb 2009
    mississippi
    lol
    now have
    65 lbs
    99 lbs
    170 lbs
    what he sead if you had a race car it would be one thing but you have a 4x4 truck
    Can I vote twice? 100 is the closest answer... there, I'm stuffing the ballot boxes.
    Maybe I should take some pics of me weighing them next time I have a bare iron block to weigh, the 2 I have right now still have cranks, cams and covers on them.
    Mike
    Pittsburgh, PA
    i had read in the LS1 books it was 90#
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
