Results 1 to 10 of 10
Thread: fuel pump
    Feb 2009
    fuel pump
    Hi All,
    i need a external Fuel pump and Fuel filter for my 6.0 Vortec swap in my Jeep Cj-7,what Brand fits best?
    I found these Pumps at Summit ,ok or not ?
    Walbro GSL392 - Walbro High Pressure Inline Fuel Pumps - summitracing.com
    Walbro GSL394 - Walbro High Pressure Inline Fuel Pumps - summitracing.com
    Thanks
    Hardy
    Jun 2007
    Those are not externals ,theyre intank pumps.look into some aeromotive pumps and accessories theyre top notch stuff,use the proper filters and stuff with em tho or youlle be wasting youre money.theyres alot of them out their but these are what i have with no issues,do it once and right or youll be doing it again.If u have more questions feel free to ask.
    Feb 2009
    In the description from Summit i read ...Fuel Pump, Electric, External, High Pressure, 255 lph...?
    Jun 2007
    naa theyre intanks ,i know i installed 3 in my truck.edelbrock has some pretty nice externals1s also.they could be describing them as a boosta pump to work inline with yours.but that is not what you want.
    Try the Bosch 044 pump. They should easy to locate over there since that's where they're made. The exact part number is listed on the sticky on the front page of this website about sumping a fuel tank.
    Feb 2009
    ok...
    Thanks
    Anaheim Hills, CA
    Is there a problem with the "High Pressure" or does that just designate EFI vs. carb?
    ...........Workin' on it...........
    Feb 2009
    I have no problem with the fuel pressure,in need a new one for my Swap.
    When i buy the Bosch 044 it is a fuel pressure regulator necessary for my 2003,6.0 Vortec ?
    Since it will most likely be a single inlet fuel rail you'll need a regulator. I just use a Corvette fuel filter from a 2000 model, it has a built in regulator and return fitting to send the excess pressure back to the tank.
    Apr 2006
    Muldrow, OK
    Like Greg said, the Corvette fuel filter works great and keeps the length of return line hose down to a minimum (~2ft in my case). One last tid bit is just be sure and run fuel injection quality hose and double hose clamp any slip on fittings in the fuel system.
    -Slow Is Not An Option-
    93 Stepside - Forged 347 - LS6 intake - Stage II LS6 Heads - MTI X1 Cam - Vigilante 2800 Stall - HP Tuners - Schoenfeld Headers - 4.11's w/Powertrax - Caltrac's - 430/400
    02 Trans Am - Forged 408 - Single Plane GMPP - 96lb/hr Injectors - HPT 3 Bar - Twin 67mm Turbonetics - Huge FMIC - Moser 9" - 4L80E - Alky Control Meth - Jesel J2K - Eboost2 - waiting dyno
