Results 1 to 7 of 7
Thread: Weird A/C Problem..Please Help
    Feb 2005
    This in regards to my 1994 GMC Truck, here as of recently Ii've been having weird A/C electrlical issues. Heres my story.
    On any given day I can jump in my 94 GMC Sierra and can say without a doubt 90% time the A/C isnt going to work. I crank the truck up and let her warm up for a bit. I hit the switches to turn the A/C on (electric display unit type) and she doesnt work. I have no air flowing from the vents what so ever. I can hear a slow "hiss" for a second but thats it.
    Now heres the weird part.......
    After driving for a moment I turn the A/C off and look for a bit of open road. I can go from a slow roll and punch the gas. I stay on her WOT till she shifts into a higher gear. I reach over and turn the A/C back on and "VOILA"...my A/C suddenly works again? What gives.....This works most of the time but is really annoying. I have checked all my fuses and connections under the hood that I know of. Anybody got any ideas?
    http://img.photobucket.com/albums/v6...h/71d2d8df.jpg
    2002 Dodge Ram Quad Cab
    **Stock**
    1994 GMC Sierra SL
    **coming around**
    Sounds like the dash mounted control cente is going out or is corroded internally. Borrow a buddy's and switch it out for a day and see if it fixes your problem. My 92s took a crap at 4 months old. It was replaced and had worked perfectly after that. Salvage yards are full of the modules.
    Feb 2005
    Well I got some free time today and tore into the black beast. I removed the inner glove compartment exposing some relays and some of the plastics underneath the dash to assist with checking wire connections etc.
    I exposed the main control panel and checked the connections..all was good. Check every connection in the dash wheither it wa A/C related or not assuring that all were not corroded(SP) and properly seated. Still, my A/C would not work. As a last resort I got ticked off and hit the blower motor with the end of my trusty screwdriver. Wouldnt you know it the damn thing kicked on
    So I am figuring that the blower motor may be on its way out or there is some trash/debris in there keeping her from spinning on command. Ill keep you updated on my findings. Thanks again
    **Stock**
    1994 GMC Sierra SL
    **coming around**
    San Marcos Texas
    When the brushes get warn out on you blower motor, it will do just what you said.
    Feb 2005
    how hard are they to replace......possiable link w/pics?
    **Stock**
    1994 GMC Sierra SL
    **coming around**
    My power leads to the blower in my old 92 corroded at the connectors inside the cab. There is a lead coming in from the fire wall that has a large guage red wire and two tones of green leads that melted on mine and the blower quit working. I replaced the connectors with crimp-on butt connectors and no more problems. There are also about 4 relays behind the glove box for misc items but I have never seen one of them fail.
    Feb 2005
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jun 7 2005, 10&#58;26 PM) [snapback]28471[/snapback]</div>
    Bringing this back from the dead. Sorry it took so long to get back to you guys. It turned out to be the blower motor. I got a new one at Discount Auto Parts for like 40.00. Took about an hour for me to install and man does that bitch blow. Being a single cab truck, she really cools off really quick..damn near frigid. Thanks for your help.
    **Stock**
    1994 GMC Sierra SL
    **coming around**
