Results 1 to 10 of 15
Thread: A quick update
    I've been going back and forth on the turbo decision. Do I do one big turbo or two smaller ones?
    Well, after throwing around ideas for a long time, I just dove into it and decided to do twins. This stuff is a lot easier than what I was expecting. This only took 2hours, but it's also only tack welded.
    It's not much, but I built a simple header for the drivers side. I figured if I could build a header for the driver side and get it around the steering and engine mount, I'd easily be able to build the passenger header. The passenger side has all kinds of room.
    The header is made from 16g mild steel, but it's just a mock up. The collector will be cut off, about 2 more inches, then I'll add a 3" U-bend on top of it, weld the flange on and then bolt the turbo on.
    The passenger side will look the same.
    Once I get it all done, I'll rebuild it in stainless steel and finally be done.
    The mock up has plenty of room, the plugs clear and I should be able to route some custom plug wires around the headers.
    Here are a few pics.
    Stage7
    Any suggestions on turbo sizing, wastegate options, intercooler routing, websites for parts, is greatly appreciated!
    allen
    May 2004
    Damn Allen, Why did you make me have to look at something like that!! Now I'm gonna have to do something similar after I get up and running. I think you'll be fine with those unless your wanting to go 1500 HP or better. LOL
    BTW, I was needing to see what coils you had. Thanks for the pics, now I might be able to get your brackets going.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    i never knew you could make your header turned 180 degrees like you have it. is it possible to do two rear mount turbos or do you have to have them mounted in the front?
    <div class='quotetop'>QUOTE(duckysbht &#064; Apr 25 2006, 08&#58;35 PM) [snapback]51205[/snapback]</div>
    hey ducky, sure, it doesn&#39;t matter which way the exhaust flows, especially for a turbo. Yes, it sure is, I was actually thinking about that before I decided on this. You&#39;d simply make or buy some shorty headers and bolt the turbo right to the collector, with a little fabrication of course.
    Hey Nitrous, it&#39;s not my fault, lol, jk. Glad the pics helped on the bracket design. It&#39;ll look nice and clean with the coils on the back of the head and smooth valve covers.
    thanks guys,
    allen
    <div class='quotetop'>QUOTE(farmtruc &#064; Apr 25 2006, 09&#58;41 PM) [snapback]51206[/snapback]</div>
    thanks guys,
    allen
    ok that makes sense. are those turbos for your 94? or the gto?
    Feb 2005
    Looks awsome Allen, let me know when my truck it&#39;s next.
    2001 GMC Silverado
    Stock Bottom End LQ9, MS3, Stock 317's, Victor Jr, Aron's Elbow, 90mm TB, 1 7/8 TSP headers, FLT 4L80-E, Rossler Trans-Brake, 3600 PI TQ, 4.10's, 31" tire. Nitrous Dave System with Zex plate. On 150 shot 10.53 @ 128MPH 1.51 60'
    Old Setup = Trick Turbo Kit Tuned/Installed By Nelson Performance 10.78 @ 127.08 1.62 60'
    I haven&#39;t decided on the sizing yet, but yes, the turbos are for the truck. The gto is staying na.
    allen
    Jun 2004
    george west texas
    man thats sweet allen....2 hrs to mock up those..hell you should have the other side done by morning then looks good dude&#33;&#33;&#33;
    hahaha..check out jj...hes ready for some twins already&#33;&#33;&#33;&#33;
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    <div class='quotetop'>QUOTE(JJ_NLTO &#064; Apr 25 2006, 08&#58;52 PM) [snapback]51210[/snapback]</div>
    LOL JJ, you just can&#39;t get enough power or what, jk. I sure will. In the back of my head, I have some ideas brewing.
    <div class='quotetop'>QUOTE(bud8fan &#064; Apr 25 2006, 08&#58;53 PM) [snapback]51212[/snapback]</div>
    ya, it was very quick, I was really surprised. I will get the other side done tomorrow. I tried tonight, but I just have too much email to answer, got to put the business first. I&#39;ll sneak some time in for the ol truck tomorrow evening though.
    see you two guys soon,
    allen
    Looks good, Allen Once you get it designed you can send them out to have them mass produced and you can market them to others. I like the single turbo idea for simplicity&#39;s sake but I&#39;m sure what you&#39;re doing is going to work great. I can&#39;t wait to see the truck on the track again&#33; Did John ever get your wiring harness installation finished?
