I need a cheep 4L60E tranny from an LS 5.7L truck.
I want to rebuild it myself...........so If you have one kicking around let me know.
Thanks
 Junior Member
						Junior Member
Thanks
try to find someone on the net who is thinking about going with an upgraded trans and see if you can buy his core.
just a thought.
here's one from ebay
here's another one
one more
good luck,
allen
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
TBYRNE has a couple of trannies for sale used. I was thinking about getting one.
 Senior Member
						Senior Member
						i have one out of an 02 475.00 this is a good trans not a core.
austin
800-447-0611
Austin Jenkins
Hi-Way Auto Parts
Brownwood Tx, 76801
800-447-0611
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						Hmmmm..... 5.7L LS in a late model truck? Cool.
 Senior Member
						Senior Member
						.......... 550.00 for a good trans out of 98 1500. with 48K
Greg he has the listing as a 1999-2002 trans is what he is hunting then he types one for a 5.7. guess i will just cover both ways
Austin Jenkins
Hi-Way Auto Parts
Brownwood Tx, 76801
800-447-0611
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						98 C1500 has a different transmission than the 99 doesn't it? the bolt pattern, torque converter, bell housing, input drum and pump stator are different on the 5.7L trucks than the 4.8, 5.3 and 6.0L engines, correct? I know you cannot put a 98 4L60E in an LS1 without custom parts to make it work. Isn't the bolt pattern on the 4.8, 5.3 and 6.0L engines the same as the LS1/LS6 block? I know they are basically the same engine only in cast iron instead of aluminum.
I have a 4l60e out of my 2002 gmc sierra. It needs to be rebuilt because it started slipping but it has a transgo shift kit and corvette servo in it. If you want it you can have it with the torque convertor for $300Originally posted by GREG_92_C1500_2001_LS1_A4@Nov 19 2004, 10:25 PM
2002 GMC Seirra scsb, 5.7LS1, Twin 62-1 turbos, Compcam 222/218, 4l80e, and Hptuners
2006 GTO Black/Red, 6.0 M6, 238/240 cam, SW LT, exhaust & bolt ons = 438rwhp411rwtq!
