Results 1 to 10 of 12
Thread: my buddys truck
    Feb 2009
    Houston
    my buddys truck
    my buddys truck is making a noise.we thought it was the ac tensioner pully.changed it.and its still doing it.we took the ac compressor belt off,and it still makes the noise.it sounds like its coming from the left side of the engine.the engine only has 50,*** on it.
    Take the fan belt off and see if it goes away. Alternators are notorious for squeeky bearings.
    Sallisaw OK
    waterpump? i would eliminate the belt first, if you spray it with windex it will stop squeaking if it's just the belt. It is amazing how a squeaky belt can sound like a bearing sometimes. If the windex doesn't make any difference do like Redheartbeat said and take the belt off and run it for a sec.
    i sometimes will take a piece of garden hose put one to my ear and the other as a probe to isolate exactly where the noise is coming from.
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    Crossett,Ar
    I had a bad Alt a few weeks ago that made a sound kinda like this, Im with red, Take off the belt and see what happens
    Aight the truck making the noise belongs to me!
    My homeboy posted the video up for me and so far we've taken the belts of and ran it with no belts and the noise is still there.
    Some mechanic said it was the timing chain another mechanic said it can't be that. So now I'm like WTF?!
    Cuz two mechanics same something different!
    Some body help!
    sure sounds like an idler bearing.
    Start swapping parts from one truck to the other until you find the culprit.
    Bakersville, NC
    Good luck, mines also making a noise and alos thought it was the tensioner, but wasnt. But mine sounds different and dose it while going down the road at a certain rpm. Keep us posted on what you find.
    David,
    2003 GMC Sierra Denali, LQ4, AWD, AWS, 4.10, Wheatley 93 tune, LT headers, GMPP CAI, BBK 80mm TB, MSD wires, E3 plugs, 160* T-stat, Flowmonster DI/DO, cutouts. Working on 4.8 heads, just purchased Comp 228R cam, 918 Springs, TI retainers, 7.4 hardend pushrods,
    Sallisaw OK
    Quote Originally Posted by 567234ta View Post
    Quote Originally Posted by V8orVnothing View Post
    Some body help!
    have you tried the hose? it actually works really well.
    6.6L 4l80e
    MY GARAGE
    Feb 2009
    Houston
    the noise is coming from inside the timing cover....
    and runs all the way back towards the flywheel
    The oil pump is behind there and I just wonder if there is a major oiling issue. Some here have heard bearings squeak or rattle when they're starved for oil. How much do you trust the stock oil pressure gauge?
