I'm going to go with something larger due to the under-hood temps of the turbo. These worked great before the turbo and are doing good now, but I would like it a little cooler under there.
The frame could use some spray paint, but has been fabricated to fit with no issues. The bottom of the square tubing is notched to slide over the flange at the bottom and the top bolts to the stock threaded inserts. I believe this should fit 99 and up. Not sure about the NNBS.
The Hayden fans are typically around $100.00 each, so I feel the price is pretty fair.
I'm asking $150 picked up or $175 shipped.
