Results 1 to 10 of 10
Thread: Motor shakes
    Oct 2007
    connecticut
    Exclamation Motor shakes
    Heres the prob: 2002 5.3liter with 94,000 miles on it, starts fine-engine is noisy due to lack of oil lubrication on initial start up. but mine is a little extra noisy. seems to idle fine, sometimes lopes a little bit. when i give it little gas and hold it(about 800-900rpms) the engine shakes like crazy-vibrates the whole body. above 1000rpms shaking goes away. ive heard about cam lobes getting worn, but i am not sure that this is the problem. this engine has had much abuse, but always the finest maintainance(Mobile 1 full synthetic every 3000 miles religiously, fuel filter every oil change, new plugs and wires,etc).
    Any help will be extremely appreciated. I would love to continue going to the track, but i do not know if i am just doing further damage to an exsisting problem.
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    Dec 2003
    Azle,TX
    Ignition or injector problem...my 2 cents
    Vortec Performance Tuned
    injector would be my guess.
    Oct 2007
    connecticut
    huh.... i would have never guessed injectors or ignition...shows how much i know
    ff_jeff Guest
    It doesnt like you. Just my 2 cents.
    Oct 2007
    connecticut
    hey, my truck loves me
    Oct 2007
    connecticut
    ttt
    Yeah--sounds like a fuel issue to me as well. No CEL for KR?
    Dave, you could take the injectors and fuel rail off and soak them in some warm water and mineral salts for 1/2 a day. Then use low pressure water to hose them out. Or you can send the injectors off to have them disassembled and cleaned. If you do so, make sure to get some new o-rings for the injectors.
    Cam lobes rarely ever go bad in a hyd roller set up. Read the spark plugs to see if you have any lean or rich cylinders. Might run some fuel system cleaner and it wouldn't hurt to swap the inline filter if you haven't done so in a while.
    Southeastern Wisconsin
    when i did the cam swap on my truck, i put in new injectors at the same time, and before the swap i had the same shake. When i took my fuel rails off, i noticed that the FPR screen had a hole in it, so as far as i know something was in there because it was a decent sized break in the screen.
    FYI you cant buy the screen seperately
    Hope that helps a little.
    1999 GMC Sierra SLE ECSB .... 5.3L w/ Slight Performance Tune / True Duals with Flo Pro Glass Packs.
    Project ''Bad Company'' Future = 6.0L (Forged Internals) / Boost (TVS) / 4L65E LvL 5 / AWD Conversion / Full LT's with Cats / Methanol Injection / Lowered 2" / SS Rims / Frame Up resto
    Officially Employed!!!
