Thread: torque specs?
    torque specs?
    I did a search, only found http://www.ls1truck.com/forums/lsx-t...s1-swap-2.html
    I have a lq9 and i doing a cam and spring swap and oil pan. Are these the same specs for the lq9 as they are for the ls1?
    thanks
    fred
    Surprise, AZ
    Quote Originally Posted by Justblazin View Post
    thanks
    fred
    I'm sure they are somewhat acurate. However, I don't know fi I would recomend tightening the intake maniflod to 89 ft lbs. If you do you will snap the bolt off. Thats if you are pulling the heads. I didn't see the timing chain cover spec. I think that is 18ft lb. I think the other ones are good. Other than that you can try to get a mechanics book from autozone or checker.
    Same torque specs on the cam stuff.
