Results 1 to 6 of 6
Thread: Cluster lights
    I would put this in the right section, but hopefully i can get faster reponses here. I got bought a new escalade cluster for my truck. Now i have the check engine, air bag, and battery light on. How do you remove the little light that lights these up.
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    <div class='quotetop'>QUOTE(graysilverado5.3 &#064; Jan 22 2007, 09&#58;54 PM) [snapback]80829[/snapback]</div>
    first of all, figure out why those are turning on. second of all, here; read this, http://www.gmfullsize.com/forum/showthread.php?t=24726. that will tell you. By the way while your doing that you should buy my white LED bulbs that will fit it and make your cluster look badass. Here is the FS for my LEDS im selling. http://forum.ls1truck.com/index.php?showtopic=10001
    hope that helps.
    Thanks man, but i just want to not see those lights.
    Jan 2007
    well if you break those lights you can fail emmisons. i dont know if were you live has emmisons but my area does and they scan the computer and see if the check engine light is burnt out. i would just go to someone with a scanner and clear the codes.
    No, they don&#39;t check the emissions here. And my truck won&#39;t pass emissions anyways haha. I have a very good "friend" that passes my truck when its that time. I fixed the problem, i just put electrical tape over the holes where the lights are BAM problem fixed.
    Jan 2007
    Burleson,TX
    well your lucky then...i would still find out why they are one you never now if a small problem grows into a big one..
    06 silverado CC Volant CAI/ Corsa Sport exhaust
    dynatech supermaxx headers/cats
    LPE GT2-3 cam/ Comp 918's/ Rods
    Eaton LSD 3.73's
    IAT Shocks
    DANNY TRANNY w/2800 TCS billet verter
    275HP and 293TQ Pre Cam
    314HP and 303TQ post cam
