Results 1 to 6 of 6
Thread: LS2
    Apr 2006
    Hi everybody.....
    I have a problem and I wish that someone can give me the solution, I have silverado 2006 model 5.3L and I want to swap LS2 2005 complete corvette engine in my truck and I want to know what I should I do to fix this engine in my truck. ................
    OJOOJO
    Oct 2005
    drinking your alcohol
    little more info... i dont knwo about any one esle... but are you wanting to fix your 5.3 or swap that one for an ls2?
    DamnYankee: my nana failed
    Oct 2005
    Baton Rouge, LA
    the way i read it... looks as if they are asking how to fit teh LS2 in the truck.
    Apr 2006
    <div class='quotetop'>QUOTE(OMAIR &#064; Jan 11 2007, 04&#58;47 PM) [snapback]79318[/snapback]</div>
    Hi everybody.....
    thank you for replying and I have 5.3L engine now in my truck, and I want to swap it by LS2 engine 2005 , and I want to know how and what should I need to swap the LS2 engine......
    OJOOJO
    Nov 2006
    Plano, TX
    I&#39;ve not done it yet, but from my research -
    Physically the engine should bolt right in and use all accessories. The only concerns I see are the crank sensor, cam sensor, and knock sensor locations (you may have to extend the harnesses, check Speartech) and verify that the crankshaft reluctor wheel is the same tooth count as your 5.3L (so it will work with your existing PCM). Sorry to not have more concrete answers, I&#39;m not that familiar with the specifics of the latest 5.3L mills.
    Mr. P.
    Oct 2005
    <div class='quotetop'>QUOTE(Mister P &#064; Jan 12 2007, 11&#58;07 PM) [snapback]79517[/snapback]</div>
    Mr. P.
    well since you havent done it yet, tell ya what..... go ahead and buy the engine and allother things that are needed and ill let you get a few wrenching hours of practice in on swapping my 5.3 out and the new LS2 in...sound like a deal?? good thats what i thought... ill be waitin on you monday
