i saw some post about problems with e-fans and the wiring should i expect the same, and will pcm need to be worked on so they could work with the wiring harness?
and i also have an 2003 dash cluster i guess thats what its called, well the thing with all the guages well it goes up to 120 and mine is 2001 only goes to 100, can i swap them out easily or should i not even try i'm pretty sure i seen acouple of older truck with that setup.![]()
