Results 1 to 6 of 6
Thread: engine swap 350 crate engine
    i was woundering if anyone could help me on what to do with the tbi and computer.
    http://www.jegs.com/webapp/wcs/stores/serv..._22627_-1_10763
    the 260hp 350 is the one i will use it is from jegs if you haven't looked at the link yet. i just need to know if i could get the computer programed from nelson or were to go for this. also could i get a setup for my laptop computer to program it useing that. any help that anyone can give me is appreciated and thanks in advance.
    also if anyone needs a 4.8 vortec send me an email at rudabag@yahoo.com have decided not to swap into my truck. since this will be a hunting truck, and my parents are going to order me a new 2007 sometime soon. its great when your parents want a safe college vehical for you.
    Aug 2005
    St. Anthony, Indiana
    May 2004
    Tunercats makes a pc based program to tune your vcm. Are you installing that engine in your 93? If so you might want to consider one with center bolt valve covers and one that is recommended for 87 up. The LO5 was the original engine GM part # 12520270 or #12568758.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    would i be better to go with the 350 HO that gm puts out for the crate engines because i really don't want to use the stock style that gm puts out for the 1987-1995 it just doesn't have enough power for me. this is going in my 1993 chevy silverado. i need to have some power for pulling, and just because you can never have enough power. if anyone has any more suggestions for my please reply i could use all the suggestions anyone wants to give.
    Feb 2006
    i didnt look at the link, but i think if you are referring to the old style engines (pre-88) that the accessory bolts in the front of the heads may not work with your tbi accessries? Im not real sure though.
    <div class='quotetop'>QUOTE(redbandit98 &#064; Jan 16 2007, 08&#58;58 PM) [snapback]80055[/snapback]</div>
    but it should work if i choose to put vortec heads on and use gm performace parts vortec tbi intake.
    well thanks for the info also found out the only what to use that motor is to use different heads or i would have to run a carberator. not what i want to do fuel injection is the only way i would go. unless the vehical came with a carb.
    Like a yenko camaro now that needs a carb 750 demon carb thats cool.
