Results 1 to 5 of 5
Thread: Fun with a BMW Z3
    My brother and I were out collecting a few HPT log files to send over to Allen when on the way home we pulled up next to a Z3 at a stop light. He wasn’t sure if he wanted to go or not so he hesitated off the line and couldn’t catch me. At the next light he wanted to go. So the light turns green and he beats me across the intersection, hits second then I start to gain on him. This continued at the next two lights also. Made me feel kind of good that he couldn’t get away from me in his little sports car that cost a whole lot more than my truck.
    Awesome kill . Dont much like the looks of those z3's though, same with the z4's. What all do you have do done to the truck?
    2004 ECSB 5.3/4l60e, intake, exhaust, shorties, efans, Nelson tune, comp 212/218 558/563 115 lsa, comp 918's, comp pushrods, shift kit, servos, etc.
    <div class='quotetop'>QUOTE(Scott &#064; Dec 14 2006, 07&#58;44 AM) [snapback]76295[/snapback]</div>
    2004 ECSB 5.3/4l60e, intake, exhaust, shorties, efans, Nelson tune, comp 212/218 558/563 115 lsa, comp 918&#39;s, comp pushrods, shift kit, servos, etc.
    How does that shift kit feel witht he servos and the tune? Can you break them loose in second pretty easily?
    <div class='quotetop'>QUOTE(duckysbht &#064; Dec 14 2006, 09&#58;01 AM) [snapback]76317[/snapback]</div>
    No, just a chirp with a nice firm shift. I found this advice some where, I think it was from HitmanX on PerformanceTrucks.net,
    "put the stock springs back in and turn the piston around the way it was
    A big issue is the accumulator valve for the 1-2, you need to install the softest spring
    Stock springs will soften it up a good deal, I DO NOT recommend drilling the 1-2 feedhole out at all. 2-3 go .110 and the 3-4 .125"
    I also have the line pressure set at stock. I love the way the trans shifts. Not harsh at all, just nice and firm when you need it to be.
    Here&#39;s my parts list:
    TransGo HD2 shift kit
    4L60E 1-2 aluminum accumulator piston (small pin)
    4L60E forward clutch aluminum accumulator piston
    Corvette servo 4L60E W/ longer pin
    Superior 4th gear billet super servo
    TransGo separator plate
