Good for about 2" drop on 1/2 torsion suspension. 2 months old.
For sure works on Silverado SS, VHO. Maybe Tahoes too.
Boxed up & ready to go. $35 shipped
Gone, but not forgotten!
Does this mean you have the spindles in????
ttt
<div class='quotetop'>QUOTE(jethro_3 @ Oct 26 2006, 09:35 PM) [snapback]71335[/snapback]</div>Nope, extra set.Does this mean you have the spindles in????
ttt
<div class='quotetop'>QUOTE(SCIV @ Oct 26 2006, 09:53 PM) [snapback]71322[/snapback]</div>Do they make the ride rough? I have turned my stock keys down a good bit and taken the 2" riser out of the back of my 4wd Would this safely and smoothly get me lower?Good for about 2" drop on 1/2 torsion suspension. 2 months old.
<div class='quotetop'>QUOTE(zeake @ Oct 27 2006, 10:55 PM) [snapback]71456[/snapback]</div>I cut the front bumpstops down, so it doesn't ride too bad to me.Do they make the ride rough? I have turned my stock keys down a good bit and taken the 2" riser out of the back of my 4wd Would this safely and smoothly get me lower?
That is a very subjective feeling to try and describe. I am not too sure there are many ways to lower without affecting ride quality. If you shorten the suspensions travel, it has to be firmer to compensate.
If you are worried, go spend $225 on drop spindles. 35 bucks is cheap & easy.
<div class='quotetop'>QUOTE(Z71sierra7787 @ Oct 27 2006, 11:09 PM) [snapback]71457[/snapback]</div>That I am not sure of.Wouldnt those also lift it some more also if you wanted to go up with it instead?
1999 GMC Sierra Z71 Ext Cab, True Dual Flowmasters with X-Pipe, True Flow Intake, MSD 8.5 Superconductor wires, 180 Thermo, TB Bypass, Optima Battery, Synthetic All the way around
http://i139.photobucket.com/albums/q...7787/Truck.jpg
<div class='quotetop'>QUOTE(Z71sierra7787 @ Oct 27 2006, 11:09 PM) [snapback]71457[/snapback]</div>The purple keys lower a 1500, the green keys raise a 2500.Wouldnt those also lift it some more also if you wanted to go up with it instead?
I knew there was a color that lifted, thanks
would those keys work on my 02? if so how much would it be to ship them to 55433
04 Grand Prix GTP
03 Z71 wanting a Turbo ,Stall, and Tune BAD
THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
<div class='quotetop'>QUOTE(02CHEV @ Nov 3 2006, 10:20 AM) [snapback]72068[/snapback]</div>If it is a torsion bar front end, then yes. $35 shipped.would those keys work on my 02? if so how much would it be to ship them to 55433
