502 BB Chevy, JE pistons, Comp roller rockers, Comp billet roller cam (cast gear), stud girdle, all ARP fasteners, oval port aluminum heads (ported), Victor Jr. intake, FAST EFI (sequential, wide band, IAC), billet throttle body, Bosch injectors, billet adjustable fuel regulator, MSD dual pick-up billet distributor, Clevite bearings, steel crank (std./std.), 7/16 rods (arp bolts), SFI balancer. Engine Dyno @ 570hp / 570tq (on 91 pump gas and 750 holley). Low hours. Will consider separating efi system from engine. $7,000
Anaheim, CA 714-335-1278
- You may not post replies
- You may not edit your posts
