OK, I'm not much for bling, but I wouldn't mind eventually going with a taller wheel (maybe 18"...nothing crazy like 22's).
Are there any tire wheel combinations that maintain the overall stock tire height while using a taller wheel?
Go 18" so if you want you can do the big brake kits.
I made the mistake and bought 17". I wish now that i would have gotten the 18" rims.
2004 EXC Silverado 6.2L
Mods:
6.2L L92, Ported and Polished stage 3 heads, 95mm Throttle Body, 100mm MAF, NA, Pacesetter LT Headers, Magnaflow X-Pipe Muffler, Electric Fans, 160* thermostat, 2" Drop Shackles, Hellwig Sway Bars Front and Rear, Monroe Reflex Shocks, NGK Spark Plugs, AMW Oil Catch Can, 17"x10" wheels on Kuhmo Tires.
<div class='quotetop'>QUOTE(shwarmy @ Oct 12 2006, 05:40 PM) [snapback]69091[/snapback]</div>Go 18" so if you want you can do the big brake kits.
Thanks Shwarmy. Are they the 17's in your sig? If so, I like them but yeah, I think I want just a little bit taller wheel than that. I think 18's would be perfect.
