Results 1 to 10 of 33
Thread: what to do, what to do...
    Mar 2006
    Mesquite
    So I'm sitting here thinking what I can do next to feed the addiction. I can't get crazy and spend thousands on a supercharger or anything, so here are my "affordable" options as I see them...can you guys think of any more?
    - Underdrive Pulleys
    - Ported Throttle Body
    - Electric Water Pump
    - Hi-Flow Cats (I think my stockers are getting plugged anyway)
    - Stickier Tires (I'm almost due for tires)
    Is there anything else without starting to spend the big bucks or adding nitrous?
    A side note - I wouldn't want to spend, say, $500 on 2 or 3 mods if I could spend the same amount and get a bunch more hp from some other single mod. Make sense?
    Aug 2005
    Houston,Texas
    I would get the asp pulley-$208 and the s3 throttlebody $159 i think, to finish your bolt-ons
    99 ECSB 5.3 LS6 CAM AND SOME BOLT-ONS BEST TIME 13.6@97MPH
    http://i104.photobucket.com/albums/m...wTRUCKS008.jpg
    DBYRD Guest
    <div class='quotetop'>QUOTE(DamnYankee &#064; Oct 4 2006, 09&#58;19 PM) [snapback]67918[/snapback]</div>
    So I&#39;m sitting here thinking what I can do next to feed the addiction. I can&#39;t get crazy and spend thousands on a supercharger or anything, so here are my "affordable" options as I see them...can you guys think of any more?
    - Stickier Tires (I&#39;m almost due for tires)
    A side note - I wouldn&#39;t want to spend, say, &#036;500 on 2 or 3 mods if I could spend the same amount and get a bunch more hp from some other single mod. Make sense?
    in all honesty u could go without cats, and just get nelson to tune u out&#33; 0 dollars&#33;
    i agree with adrenaline. also if you want go ahead and gut your cats and then when your ready just buy some high flows. im not sure what it would sound like but just another thought about the cats situation.
    Aug 2005
    Houston,Texas
    yeah, cut them off alot cheaper. I have seen the aftermarkets cats cost up to &#036;150 a piece
    Jan 2006
    It might sound funny if you gut the cats. I think I would go with the u/d pulleys and the ported t/b and axe the cats if emission aren&#39;t a problem. What do you got for gears in that thing?
    Apr 2003
    League City, TX
    <div class='quotetop'>QUOTE(motoxlifer &#064; Oct 4 2006, 10&#58;11 PM) [snapback]67932[/snapback]</div>
    custom tune, and not a handheld tune . . .
    Mine - 04 Crew Cab Silverado 2500, 6.0L - L92 heads/intake - 4L80e - 4wd
    Wife's - 08 Trail Blazer LT - stock - every option - slow !
    Vid of my old Silverado 6L <---
    99 Fountain - 27ft Fever - 502 mag MPI :-)
    Dec 2003
    Newark, Tx.
    408. oh, wait, you said cheap.
    S3 tb is next..
    Oct 2005
    drinking your alcohol
    NAWZ
    DamnYankee: my nana failed
    Nov 2005
    and if you need the exhaust to just look stock for inspection or something..pull your cats off and get out your air hammer and punch out the stuff inside...haha
    Project: 91' short wide:
    GMC front end update with billet grille and all clears, 17x8 & 17x11 Torq Thrust II's
    5/7 drop, almost totally shaved and 93 Deville tails
    Future Plans: 2001 LQ4 6.0L & a T-56
    DD: 98' 5 speed GT : Dumped Exhaust, CAI
