Results 1 to 10 of 12
Thread: pics of the swap
    Oct 2003
    TeXas
    http://i17.photobucket.com/albums/b9...5831PM-2-1.jpg <--- TimeSlip
    RCSB 5.3 N/A 12.31 full boltons,H/C,4.10s,3800 converter. SOLD
    04 GTO
    Both Tuned By: ME
    May 2004
    Looks good &#33;&#33;&#33;
    13.920 @ 98.94mph...[/b]
    Jul 2005
    Loganville, GA
    looks awesome, what did you use to shield the heat on your intake tube? is that header wrap? looks functional and good
    1999 GMC Sierra Z71 Ext Cab, True Dual Flowmasters with X-Pipe, True Flow Intake, MSD 8.5 Superconductor wires, 180 Thermo, TB Bypass, Optima Battery, Synthetic All the way around
    http://i139.photobucket.com/albums/q...7787/Truck.jpg
    Oct 2003
    TeXas
    <div class='quotetop'>QUOTE(Z71sierra7787 &#064; Oct 2 2006, 08&#58;52 PM) [snapback]67628[/snapback]</div>
    wraping the intake tube does nothing, check it with a heat gun, same temps on outside as inside.
    I call it my conversation piece lol
    04 GTO
    Both Tuned By: ME
    Jan 2006
    Looks good, how does the intake perform compared to the stock?
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Oct 2003
    TeXas
    the cruise control "little black piece on t/b" was hitting snout of water pump so I took it loose from t/b, I was only seeing 90% at wot, it now goes to 100%, will see how it works tomorrow.
    I will modify the snout on the water pump sum more later or push the t/b out another 1/2" to see if it clears it.
    04 GTO
    Both Tuned By: ME
    Sep 2003
    Looks great Kevin,areyou are you taken it to the track on Sunday?
    Jun 2004
    george west texas
    nice work there kevin....
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Jul 2005
    Loganville, GA
    <div class='quotetop'>QUOTE(vv8 &#064; Oct 2 2006, 07&#58;54 PM) [snapback]67630[/snapback]</div>
    yeah i have the thermo tech wrap on mine and saw no difference thats why i was asking, but yeah i guess its just somthing for the sig
    Jul 2006
    College Station, TX
    How are you routing your belt?
    2004 EXC Silverado 6.2L
    Mods:
    6.2L L92, Ported and Polished stage 3 heads, 95mm Throttle Body, 100mm MAF, NA, Pacesetter LT Headers, Magnaflow X-Pipe Muffler, Electric Fans, 160* thermostat, 2" Drop Shackles, Hellwig Sway Bars Front and Rear, Monroe Reflex Shocks, NGK Spark Plugs, AMW Oil Catch Can, 17"x10" wheels on Kuhmo Tires.
