Hey all long time no talk.... I have a quick one My brother has a 00 sub He changed the oil and he nor I know how to reset the oil change reminder and he cant find the owners manual.... dumb question I know.. Thanks in advance Doug
04 Silverado SS with livernois 67mm hybrid, 60 lb injectors. PKRE Special grind cam, Meth. Nelson tune, 3500 yank, built 65e 3'' 5'' drop, 20" Centerline Stingrays.......... pretty fast for a "shop truck"
turn the key "on" (do not start) hit the gas pedal 3-5 times. it should reset
<div class='quotetop'>QUOTE(newbomb turk @ Sep 28 2006, 02:32 PM) [snapback]66987[/snapback]</div>Hey all long time no talk.... I have a quick one My brother has a 00 sub He changed the oil and he nor I know how to reset the oil change reminder and he cant find the owners manual.... dumb question I know.. Thanks in advance Doug
Turn the key on and either hold the gas for 5 seconds or pump the brake 3 times. Aint sure but it should be one of those.
Sorry Squirrel didnt see your reply.
Sheesh, so much misinformation here lately....
Squirrel is correct, it has nothing to do with holding the gas pedal down for 5 secs or tapping the brakes.
After turning the ignition to "on" without starting it, operate the gas pedal 3 times in quick succession, pushing it to the floor each time..... half throttle won't get it.....
After a successful reset, your change oil indicator will flash and then turn off.....
If it doesn't, repeat the procedure.
1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
1968 Camaro 95LT1/4L60E lots o' mods Web Page
1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
