Results 1 to 10 of 10
Thread: Could someone explain...
    Jun 2005
    Went down to Ennis Saturday for the NHRA qualifying rounds. There was some major horsepower at that place! It was awesome. One thing is bugging me though and maybe someone can shed some light on what was going on.
    During the Top Alcohol Drag/Funny Car (it may have been the Sprt Eliminations) it seemed that the cars came off the line full power then slowed down and then after about 100-150 ft turned the power back on.
    Can anyone enlighten me?
    '02 Silverado Z-71, STS Turbo @ 10psi, TRT Custom FMIC, Comp 222/218/115 cam, Patriot Gold Dual Springs, Hardened Push Rods, 60# injectors, 160 Thermo, FAL E-Fans, Nelson Harness, Yank 2600, Built Rock On VacMod 60E Transmission,Walbro 255 fuel pump, ASP Underdrive pulleys, Gibson Shorty Headers all polished up with a Nelson Street Tune
    Jan 2005
    Humble/Houston TX
    maybe they were getting crappy traction. theres one guy on one of the forums who has good luck jabbing it outa the hole, letting out then leaning back in. cant remember who tho
    old mod list: H/C/I/N/E/G 408
    Apr 2006
    That sounds to me like they were running throttle stops, but I didn't think that category ran them. I haven't paid much attention to the NHRA stuff in a while though. Our local track is IHRA, and as a track rule has banned throttle stops, simply because they make the racing very confusing to the average spectator.
    '99 GMC RCSB
    3" Body lift, 4" Rancho lift, Fox shocks
    36" BFG All-terrains
    LQ9 6.0L swap, gt2-3 cam, longtubes, LS1 fans, Nelson Performance tune
    4.8 gears/Eaton posi
    Built 4l65e
    Custom paint, roll pan, filled tail lights, relocated tail gate handle
    Future mods:
    Boost!!
    Jun 2005
    <div class='quotetop'>QUOTE(tenshikurai &#064; Sep 26 2006, 12&#58;38 AM) [snapback]66623[/snapback]</div>
    That sounds to me like they were running throttle stops, but I didn&#39;t think that category ran them. I haven&#39;t paid much attention to the NHRA stuff in a while though. Our local track is IHRA, and as a track rule has banned throttle stops, simply because they make the racing very confusing to the average spectator.
    That is it I was there on Sunday and they had the finals of the 8.90 and other classes they are using throttle stops and rev limiter to stay above the dial in time so is not to break out (or run too quick of a time). They are also will pedal it at the finish line also.
    01,Z71 Victory Red, sportside,5.3L, Flowmaster 40&#39;s, K&N Drop In, Airaid MIT Tube, TB bypass, Nelson Performance Hot Tune. Velocity Stack waste of money.
    Working to run with the BIG DOGS, tired of the porch. STS or LQ9 in the future.
    http://i56.photobucket.com/albums/g1...1/DSC02262.jpg
    Dec 2003
    Newark, Tx.
    <div class='quotetop'>QUOTE(NalgonaZ71 &#064; Sep 26 2006, 08&#58;10 AM) [snapback]66640[/snapback]</div>
    There you are. They have a dial in that they dont want to be under. ex. 9.90 cars want to run 9.90 or as close as they can. They come out hard and then a little hesitation according to the track, altitude, etc. Then the throttle stops open and they are off again.
    91_bowtie Guest
    That&#39;s pretty typical during the qualifying rounds. They jump out of the hole, and coast through the traps at 160. I&#39;m not sure of the reasoning behind it. They go all out for the real deal on sunday though.
    Aug 2005
    It is common for the big guys to "map" traction on the different tracks. Add/remove clutch or timing to keep the cars hooked. At big power levels its all about traction the entire lenghth of 1320.
    03 Chevy ECSB, Z71, 6.0L(LQ4), Maggie @ 9PSI, 4l80E, PI Vig 2800, Detroit True-Trac, 4.10, 90mm LS2 TB, Meth Injection, HSW Dry N20, LPE GT7 Cam, 918 springs, Dynatech LT's, Hi Flow cats, custom stainless exhaust, DMH cutouts, DJM Suspension Drop, E-Fans, AirAid, HPT 2Bar SD Tuned, 11.68 @ 114.2
    Jun 2005
    Thats it&#33;....I knew they didn&#39;t want to break the 8.90. Just wasn&#39;t sure how they were doing it. That is the first time I have ever seen that. Hadn&#39;t been to the drag races in 20+ years.
    Next question....How do throttle stops work? I mean besides the obvious of stopping the throttle.
    &#39;02 Silverado Z-71, STS Turbo @ 10psi, TRT Custom FMIC, Comp 222/218/115 cam, Patriot Gold Dual Springs, Hardened Push Rods, 60# injectors, 160 Thermo, FAL E-Fans, Nelson Harness, Yank 2600, Built Rock On VacMod 60E Transmission,Walbro 255 fuel pump, ASP Underdrive pulleys, Gibson Shorty Headers all polished up with a Nelson Street Tune
    Jan 2006
    I think they have a computer controlled timer on the throttle which can be adjusted to shut the fuel off for different lengths of time. Not 100% positive on how it works exactly though.
    May 2004
    One of the guys that works for me has a 7 second dragster and his throttle stop is activated using C02. It sits under the carb and acts as a butterfly valve to control flow. He can activate it up to 4 times during his pass.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
