Page 1 of 14 1 2 3 11 ... LastLast
Results 1 to 10 of 132
Thread: My 5.3L into a Jeep Wrangler
    Sep 2006
    Lafayette, Indiana
    So here's what i started with,
    1993 Jeep Wrangler (YJ)
    2.5L 4 cylinder (125ish HP)
    5 Speed Manual
    NP231 Transfercase (Aluminum chain drive)
    Dana 35 rear axle (Stock) w/ factory 4.10 gears
    Dana 30 front axle (Stock) w/ factory 4.10 gears
    What i have to install
    2000 GMC 5.3L Vortec V8
    700r4 Auto transmission
    NP208 transfercase (aluminum w/chain drive) i do have a Dana20 tcase (gear drive cast iron case) that will go in at a later date.
    Corporate 14bolt rear axle shaved 1.5" for max rock clearance (cut 2" off the bottom of pig, weld on 1/2" plate, and turn ring gear down 1/4")
    Dana 60 front axle both with factory 4.56 gears
    Should be a fun toy in the end!!
    2000 PSD F250 Super Duty Ext cab long bed 4x4 - a few mods...450+ HP 500+ lbs of torque!! (Daily Driver)
    1993 YJ "Buggy"
    1991 3/4 ton Suburban 6.2L turbodiesel
    Oct 2005
    Baton Rouge, LA
    Lovin' the BFH sittin' on the tire! They come in hella handy!
    I sent you a PM before I seen this thread. Once I get the pics & schematics, I'll just post in here for ya.
    Holla! -Ron
    Sep 2006
    Lafayette, Indiana
    <div class='quotetop'>QUOTE(1BADC10 &#064; Sep 22 2006, 06&#58;14 AM) [snapback]66057[/snapback]</div>
    Lovin&#39; the BFH sittin&#39; on the tire&#33; They come in hella handy&#33;
    I sent you a PM before I seen this thread. Once I get the pics & schematics, I&#39;ll just post in here for ya.
    Holla&#33; -Ron
    Sweetness...you gotta own a couple BFH&#39;s...you never know when you&#39;ll need one :-)
    So I only threw up a couple pics, i didn&#39;t mention my current state.
    I&#39;ve got the new drivetrain bolted together, and the motor mounts fabbed. The engine is bolted in and sitting all by itself&#33;&#33; The transmission mount howevere is still sitting on a jack, but that shouldn&#39;t take long once i modify the stock skid plate (belly pan). I ordered my fuel pump last night &#33; &#33; &#33; And should be in business sooner than i thought&#33;&#33; Thanks to this board and Ron&#33;
    I&#39;ll post more pics when i get home after work (Central time)
    2000 PSD F250 Super Duty Ext cab long bed 4x4 - a few mods...450+ HP 500+ lbs of torque&#33;&#33; (Daily Driver)
    1993 YJ "Buggy"
    May 2006
    Waco TX
    That is going to be BADASS&#33;
    Sep 2006
    Lafayette, Indiana
    <div class='quotetop'>QUOTE(Red03SilSS &#064; Sep 22 2006, 06&#58;33 AM) [snapback]66060[/snapback]</div>
    That&#39;s the goal....hoping to someday be able to roast all 4 tires on pavement....i think that&#39;d be sweet...we&#39;ll see what happens, i&#39;ve seen a guy do it with a 383 Stroker and 40" tall tires, i&#39;ll only be running 35" tall tires...
    1993 YJ "Buggy"
    Sep 2006
    Lafayette, Indiana
    Its final resting place
    the MESS
    More
    1993 YJ "Buggy"
    Oct 2005
    Baton Rouge, LA
    Hey, Chuck... I&#39;m pretty sure these were somewhere in my thread. If not, here ya go&#33;
    Here&#39;s the only wires I used from my OBS harness (even one or two of these weren&#39;t used):
    Before
    After
    Fuse Block
    Misc Wiring Schematics Used (References for 2000 Silverado)
    I&#39;ve got access to more if needed. You&#39;ll need to have the fuse block pinouts. I&#39;ll have to email those (don&#39;t have electronic copies on file).
    Sep 2006
    Lafayette, Indiana
    You are the man....you know that right?
    1993 YJ "Buggy"
    Oct 2005
    Baton Rouge, LA
    nah... just a humble guy that&#39;ll try to help where I can.
    Sep 2006
    Lafayette, Indiana
    So i added some text to one of your pics...is this right
    and what is the Pink w/white wire?
    1993 YJ "Buggy"
