Results 1 to 9 of 9
Thread: 4 piston calipers
    Jul 2006
    College Station, TX
    I want a 4 or 6 piston caliper. They must be able to fit under my 17" rims. If i have to buy a kit with the caliper and rotor thats fine. Just as long as they will fit under 17" rims. Does anyone know where i can get some?
    2004 EXC Silverado 6.2L
    Mods:
    6.2L L92, Ported and Polished stage 3 heads, 95mm Throttle Body, 100mm MAF, NA, Pacesetter LT Headers, Magnaflow X-Pipe Muffler, Electric Fans, 160* thermostat, 2" Drop Shackles, Hellwig Sway Bars Front and Rear, Monroe Reflex Shocks, NGK Spark Plugs, AMW Oil Catch Can, 17"x10" wheels on Kuhmo Tires.
    Aug 2005
    St. Anthony, Indiana
    Jul 2006
    College Station, TX
    I have already emailed them and asked them. They only make them for 18" and up rims.
    Mods:
    Aug 2005
    I've looked at brake upgrades for awhile. Don't think you will find 4 piston to fit in 17"
    SS brakes have a 3 piston that will work with 17's. Need 18's for more.
    http://www.ssbrakes.com/products/search/Ch...1500_(2WD)/2004
    03 Chevy ECSB, Z71, 6.0L(LQ4), Maggie @ 9PSI, 4l80E, PI Vig 2800, Detroit True-Trac, 4.10, 90mm LS2 TB, Meth Injection, HSW Dry N20, LPE GT7 Cam, 918 springs, Dynatech LT's, Hi Flow cats, custom stainless exhaust, DMH cutouts, DJM Suspension Drop, E-Fans, AirAid, HPT 2Bar SD Tuned, 11.68 @ 114.2
    Jun 2005
    Behind enemy lines in Kommiefornia.
    I bought a Willwood 4 piston brake setup, mostly to rid myself of the horrendous stock GM parking brake.
    The fit with 16" wheels and work great.
    Cost, about 650.00 for the entire setup less parking brake cables. Lokar makes the cables, they are about 100.00.
    2000 Silverado ECSB, 5.3L, 7" CST/3" PA lift, Hanneman 'glass fenders & bedsides, Currie Dana 60 W/ Detroit Locker, 4.56:1 gears , Willwood Dynalite Pro 4 piston rear brakes, Bowtie Overdrives 4L80E, Nelson Tune & Fan Harness, Harland-Sharp 1.8 Roller Rockers, 2200RPM Converter, Mezerie electric water pump, K&N FIPK II, Dynatech Supermaxx SS LT headers & SS cats, Flowmaster American Thunder cat back, Magnecor wires, Flex-a-lite 282 monster fans, B&M Hi-Tek trans cooler . No DEathCOOL.
    And an ls1.com decal on the back window!
    Jul 2006
    College Station, TX
    where did you buy them?
    Mods:
    Jun 2005
    <div class='quotetop'>QUOTE(shwarmy &#064; Dec 23 2006, 10&#58;13 PM) [snapback]77213[/snapback]</div>
    Summit Racing. http://summitracing.com
    2000 Silverado ECSB, 5.3L, 7" CST/3" PA lift, Hanneman &#39;glass fenders & bedsides, Currie Dana 60 W/ Detroit Locker, 4.56:1 gears , Willwood Dynalite Pro 4 piston rear brakes, Bowtie Overdrives 4L80E, Nelson Tune & Fan Harness, Harland-Sharp 1.8 Roller Rockers, 2200RPM Converter, Mezerie electric water pump, K&N FIPK II, Dynatech Supermaxx SS LT headers & SS cats, Flowmaster American Thunder cat back, Magnecor wires, Flex-a-lite 282 monster fans, B&M Hi-Tek trans cooler . No DEathCOOL.
    And an ls1.com decal on the back window&#33;
    Apr 2003
    Mansfield, Texas, USA
    Go with:
    &#39;05+ front calipers and rotors, about 13"
    Tahoe/Burban rear discs and calipers... 2 piston, about 12.3" rotors.
    If you need to stop better, get some 18" wheels and Baer or SSBC.
    May 2007
    Oshkosh, WI
    How about a big brake upgrade for a 1996 GMC K1500?
