Results 1 to 5 of 5
Thread: went to redline last night
    Aug 2006
    Wisconsin
    and it really makes me miss my camaro.. i need to get some go fast mods soon.
    here's my plan; if i stay with the 5.3(l59):
    volant forced ram-air, pacesetter long tubes (ceram coated), comp cams xtreme rpm high lift [222/224 .566/.568 112lsa], fuddle 3000 stall, nelson tune, eaton differential w/ richmond 4.10's and a radix when my wallet permits.
    if i do a build-up: either an lq9 408 stroker, or the ls1/ls2 402 stroker.. i'm leaning towards the ls1/ls2 seeing as it is a bit lighter being aluminum. but for $1000 less and 65 lbs of extra weight, an iron lq9 based stroker is very appealing over an ls2 motor, and is a direct bolt in unlike the ls2.
    as for now, this is my daily driver.. i'd build the stroker over a period of 2yrs or so. money is tight right now and i'd like to go new on everything. maybe.....
    any suggestions/input?
    brad - my fquick..
    curb feelers and fuzzy dice..
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(xlr82sxs &#064; Aug 20 2006, 06&#58;11 PM) [snapback]61794[/snapback]</div>
    here&#39;s my plan; if i stay with the 5.3(l59):
    volant forced ram-air, pacesetter long tubes (ceram coated), comp cams xtreme rpm high lift [222/224 .566/.568 112lsa], fuddle 3000 stall, nelson tune, eaton differential w/ richmond 4.10&#39;s and a radix when my wallet permits.
    if i do a build-up: either an lq9 408 stroker, or the ls1/ls2 402 stroker.. i&#39;m leaning towards the ls1/ls2 seeing as it is a bit lighter being aluminum.
    as for now, this is my daily driver.. i&#39;d build the stroker over a period of 2yrs or so. money is tight right now and i&#39;d like to go new on everything. maybe.....
    The mods you listed for the 5.3 are great. Maybe we&#39;ll cross paths on 80 again and can wind &#39;em out a bit.
    Until you get the Radix anyway, then I&#39;m out.
    Aug 2006
    Wisconsin
    <div class='quotetop'>QUOTE(Moze &#064; Aug 20 2006, 05&#58;16 PM) [snapback]61797[/snapback]</div>
    i&#39;d damn sure would like to think i could take you, but everything in my truck is stock besides the exhaust.. and even the exhaust i had installed wasn&#39;t what i wanted..
    but, either of the options i have in my head are going to take a little sweat and tears and take a decent sized divot out of my spending allowance.. it&#39;s obviously going to be a few months/years before i&#39;m satisfied. even then, who knows what i&#39;ll have cooking in the back of my head.
    i&#39;ll be keeping an eye out for that truck though for sure&#33;
    brad - my fquick..
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(xlr82sxs &#064; Aug 20 2006, 06&#58;26 PM) [snapback]61798[/snapback]</div>
    It&#39;ll be the black blur going about 110.
    Just kidding - I try to be good unless I run across someone who wants to get feisty. What time are you usually going by the Beltline exit?
    Aug 2006
    Wisconsin
    <div class='quotetop'>QUOTE(Moze &#064; Aug 20 2006, 05&#58;29 PM) [snapback]61799[/snapback]</div>
    haha
    it all depends on my day.. i usually try to only put out a 10hr day and get out of there by 3pm.. but summers are always the busiest time of the year for us, so it&#39;s been nearer to 4-5:30ish lately.
    brad - my fquick..
