Results 1 to 4 of 4
Thread: nooB questions
    Oct 2005
    drinking your alcohol
    ok nooB questions.....
    what is the diference between a wet and dry kit for nitrous.... what are the good/bad thinsg about them
    then i hear some of you guys talking about a wideband.... what is a wideband, because everyone on here that has one LOVES the damn thing apparently
    finally what are the gauges that yall talk about that has many different settings that has a read out on it.... i think i saw somewhere that Allen sells em.... not quite sure... anyways, what do they do and what are they good for
    ok thast all for now
    thanks in advance
    Alan
    DamnYankee: my nana failed
    May 2004
    A wet shot is sprayed directly into the manifold through the throttle body or individual nozzles directed athe the chamber with a mixture fuel and nitrous. A dry shot is sprayed in front of the mass air tricking the computer to dump more fuel as it's sprayed.
    A typical production vehicle uses oxygen sensors that have a very narrow resolution. When you are cruising / idling (closed loop), the vehicle is concerned with maintaining an A/F ratio of 14.7 (stoich). When you put your foot on the floor and go into power enrichment (open loop), the factory sensors do not have enough resolution to tell you an exact A/F ratio. Any system that ties in to the factory oxygen sensors can only tell you if you are richer or leaner than 14.7. A Wideband setup can tell you exactly what you are running.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Aug 2005
    St. Anthony, Indiana
    here's a pic of a wide band gauge
    i think alan might be referring to the interceptor gauges allen was selling that read a variety of functions
