Results 1 to 7 of 7
Thread: AEM wideband
    San Antonio, TX
    Hi Guys, I have a lot of customers asking for these, I'm finally getting a box of them in early next week.
    Sorry for the delay, but my supplier was a bit behind.
    These are AEM widebands and are $279.
    Just an update,
    thanks,
    allen
    Nov 2005
    ohio
    DAMN , thats the best deal AROUND on a WB, I love my AEM and it has been working great since i got it.
    San Marcos Texas
    I love mine. I didn't think I would pay it much attention but I'm constantly watching it. It also has a 0-5V output and a data output to log on a PC.
    Jan 2005
    Conway, AR
    I'll be getting one as soon as I build funds. My Lc-1 went shit on me. How hard are these to install, the lc-1 was a pain in the butt. I gotta have one bad, I have my fueling down with the fuel trims, but I know they arent nearly as accurate as they should be. It smells pig rich on cold startup too.
    <div class='quotetop'>QUOTE(chrisj6 &#064; Jul 28 2006, 09&#58;17 PM) [snapback]59316[/snapback]</div>
    I&#39;ll be getting one as soon as I build funds. My Lc-1 went shit on me. How hard are these to install, the lc-1 was a pain in the butt. I gotta have one bad, I have my fueling down with the fuel trims, but I know they arent nearly as accurate as they should be. It smells pig rich on cold startup too.
    I got tired of the LC-1 issues as well, AEM is the chit&#33;... I needed somthing more portable, I can hook it up in any car/truck in under 5 mins its a 3 wire hookup. Red to power (I use a power adapter, portablility) White PIN #1 on EIO and ground black to EIO as well thats it&#33;
    FYI ignore the gauge readings it reads 0V = 10.00 AFR and 5V = 20 AFR so it will read lean at times and is normal. After much research/email/phone calls etc... The logging in hpt is correct and dont be concerend if they report different values. Nothing major but there off slightly.
    Oct 2005
    drinking your alcohol
    ok some what a new-b question.... what does a wideband do??
    DamnYankee: my nana failed
    San Antonio, TX
    It&#39;s the only accurate way to measure a/f ratio.
    A new wideband O2 sensor is installed in the exhaust pipe, then connected to a digital gauge which shows true a/f ratio.
    allen
