Results 1 to 2 of 2
Thread: WTS: 85 GMC Jimmy, all wheel drive, LT1 conversion project vehicle
    Mar 2005
    Red face
    $3500
    Description: 1985 GMC Jimmy
    Drivetrain:
    1996 Cadillac LT1 approx 70k mi
    1997 Z28 SS heads & intake, ported, gasket matched, valve job
    CC502
    MSD blaster coil, MSD 8.8mm wires, NGK plugs
    MSD fuel pump
    cleaned injectors
    1LE intake
    TB mod, MAF descreened, AIR removed
    new GM timing chain and gears
    OBD1 ecm, cable, software, and knock sensor
    all wiring and plumbing completed, turn key motor
    http://media.putfile.com/Jimmy-running-w-open-headers
    oil cooler w/ remote oil filter
    has new additiona tranny cooler, needs to be installed
    exhaust needed
    all specs available, please email or PM
    1996 4L60-E completely rebuilt to stock specs by previous owner
    19** Borg Warner 4472 all wheel drive transfer case, brand new heavy duty custom front prop shaft
    3.73s, rear posi, front open diff
    all fluids changed, additive in rear
    Needs rear driveshaft made, have two available to work with
    1999 Corvette rims, 4 17" rims, 2 18" rims
    2000 Z28 big brake conversion, dual piston front calipers, single piston rears, still needs e-brake hooked up
    dropped 3" rear w/ blocks, needs belltech keys to lower front, can be purchased from summitracing
    needs shocks
    Exterior:
    all handles shaved, 90% bodywork completed, needs windshield, grille, front bumper and rear.
    some surface rust, body is straight
    Interior:
    all interior needs to be installed
    1997 full power blazer bucket seats
    1997 center and over head consoles
    2006 B&M quicksilver shifter still in box
    complete custom Cutlass supreme digital dash with custom programmed controller OR
    199? Pontiac Sunbird turbo gauge cluster, ala typhoon w/ boost gauge
    power windows / brakes / locks
    needs headliner and carpet
    Reason for selling:
    Major medical problems, have neurofibromatosis, multiple surgeries completed, need several more, medical bills, have tumors on / in spine, in lungs, not able to physically or financially complete vehicle
    Mileage: unknown
    VIN Number: not available, clean title
    backside of LS1 brakes finished
    custom front propshaft
    rear disk brakes
    Nov 2005
    ohio
    sweet project there! reminds me of the LT1 swap idid into my 86 iroc. Real sorry to hear about your medical problems, good luck and god bless.
