So, i just bought a 2006 Silverado Crew Cab with the 6.0L. I think im going to put exhaust on it first. What do you think about this - and what is the exhaust system to go with? I was thinking about a 50series flowmaster and dumping over the axle.
2006 Crew Cab Vortec Max 6.0L - Tune by Allen.
14.57@94mph
i would go prob with a magnaflow, or better yet the muffler on my truck!
don't go with a Flowmaster...i'd go with a Magnaflow, DynoMax or Spintech
Is it a dual in, single out? If so, be careful about drone, or really bad resonation at about 1,600 rpms. If you want to know why (since I own one) it is because the 6.0L has a bad history & so does mine. Flo-Pro is the only one that I have used that gives good performance & sound without killing your braincells. I am on my 3rd Magnaflow right now.
I have the Flo-Pro in my garage if you are interested, it will weld right in place of the factory. I changed it out because I am going supercharged and want a custom setup.
Good luck.
Gone, but not forgotten!
<div class='quotetop'>QUOTE(SCIV @ May 16 2006, 07:39 PM) [snapback]53308[/snapback]</div>Is it a dual in, single out? If so, be careful about drone, or really bad resonation at about 1,600 rpms. If you want to know why (since I own one) it is because the 6.0L has a bad history & so does mine. Flo-Pro is the only one that I have used that gives good performance & sound without killing your braincells. I am on my 3rd Magnaflow right now.
Good luck.
Yes, dual in, single out. I was thinking about dual out and dump over the axle - how did you do your truck. Also - hopefully there is a turbo in the future...
14.57@94mph
Good luck.
how much for the Flo-Pro & which model is it?? did you run duals or just a single?
14.57@94mph
<div class='quotetop'>QUOTE(MXHonda97 @ May 18 2006, 12:32 AM) [snapback]53463[/snapback]</div>I think it is the 2504, HD Big Oval series, a direct weld in. Dual in, single out using the stock tailpipe. I paid $160, I'll let it go for $85 + shipping.how much for the Flo-Pro & which model is it?? did you run duals or just a single?
Sorry if this seems like a million questions - but is it better to go with a single out or dual?
14.57@94mph
<div class='quotetop'>QUOTE(MXHonda97 @ May 18 2006, 09:13 AM) [snapback]53472[/snapback]</div>Depends on what you are looking for, and how much you want to spend. Good thing about the Flo-Pro is that is welds in place & was designed for the 6.0L. So you get to reuse the stock tailpipe & save cash. If you are going for just a good sound and a little more power, I would go that route (just like I did). But if you are going for a huge HP monster or FI (like I amSorry if this seems like a million questions - but is it better to go with a single out or dual?
[/b]), then I wouldn't.
Just replacing the muffler is cheap. If you want to spend more & get more sound and possibly more power, go for a dual out setup.
I am sure someone will chime in with their thought on this.![]()
Good Luck.
Thanks for the input!
14.57@94mph
