Thinking about doing some mild porting on my TB. Does anyone have any suggestions,tips,advice, or reasons why I shouldn't before I get started.
[1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
Well I'm already done with it now. Thanks for the help anyway.![]()
how did it go and what did you use to do it??? i polished mine and was thinking about porting but was kinda scared.
2001 GMC Sierra C3 with the 6.0! Vararam King Cobra, TB bypass, No cats with two 3 inch cut outs and thats it for the motor. FOR NOW ATLEAST!!
9.5 in the 8 mile
6000K xrtalight h.i.d kit
I used a dremel with a sandpaper roll. I took off the ridge at the bottom even to the bore and blended it in all the way around. I also ground off the backside of the screws that go through the blade & shaft as well as flattening out the shaft quite a bit on the backside. I did the bumpstop mod too. I was pleasently suprised with the throttle response afterwards, I didn't think it would make a noticeable improvement but it did.![]()
tell me more about this bumpstop you speak of
1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
<div class='quotetop'>QUOTE(metalmulisha777 @ May 14 2006, 04:32 PM) [snapback]53106[/snapback]</div>shaving down the bumpstop so the blade will open 100%. dont do this unless you know what your doing! if you go too far it will help more than it helps. you need a volt meter hooked to it. search around. theres instructions somewhere to get it perfect. its either here...pt.net or ls1tech.tell me more about this bumpstop you speak of
Here's a link to it. I haven't noticed any ill affects. I think it will cause problems if you go too far.
http://www.installuniversity.com/install_u...rsity/index.htm
<div class='quotetop'>QUOTE(TXsilverado @ May 14 2006, 05:39 PM) [snapback]53107[/snapback]</div>BTW if it helps more than it helps I guess it's a win win situation.shaving down the bumpstop so the blade will open 100%. dont do this unless you know what your doing! if you go too far it will help more than it helps. you need a volt meter hooked to it. search around. theres instructions somewhere to get it perfect. its either here...pt.net or ls1tech.
[/b]![]()
I found this after the fact and I think I'm gonna pull my TB back off & do a complete port like this. It doesn't look too hard. I just thought I would post it up in case any of you guys wanted to do it also.
http://www.geocities.com/wilwaxu/throttlebody.html
<div class='quotetop'>QUOTE(motoxlifer @ May 16 2006, 12:29 PM) [snapback]53254[/snapback]</div>thats the best write up ive seen.I found this after the fact and I think I'm gonna pull my TB back off & do a complete port like this. It doesn't look too hard. I just thought I would post it up in case any of you guys wanted to do it also.
