How involved is the 4L60 to 4L80 swap. What extra parts will I need to install in my 04 crew cab? driveshaft, mounts, harness????
2013 2wd Z71 6.2 crew cab
Old Truck: '04 Chevy crew cab stroked/bored 6.0 to 408ci. forged internals, patriot 68cc stage 3 heads (11.1:1cr), comp 244/246 .600 115lsa cam, 3000 yank tc, built 4L60E, walbro 255, 60# mototron injectors, pacesetter lt's 4" single no-cat exhaust
best time 12.93 1/4 mi @ 103 in the turbo truck.
1968 Camaro Convertible, super sweet!
possibly a spacer, modify the crossmember, modify the harness, get someone to upload a file for the 4l80, stall.
<div class='quotetop'>QUOTE(trtturbo @ May 3 2006, 09:02 AM) [snapback]51915[/snapback]</div>and a new 80e converter...possibly a spacer, modify the crossmember, modify the harness, get someone to upload a file for the 4l80, stall.
'13 silverado LT...stock
'11 lt 4x4 z71..tvs1900
that answer was for you too Alton.
I dont expect any big deal as far as your crossmember goes. There are several locations to move it to and should be easy to modify.
The spacer runs about $30.00 and the longer bolts neede run about $30.00 from G.M. part #'s 12563532 & 12563533
I would think Allen could take care of the program w/o a problem.
THe harness,if Allen doesnt have it is $160.00 from Speartech.
THen, the more expensive stall.
<div class='quotetop'>QUOTE(trtturbo @ May 3 2006, 09:26 AM) [snapback]51925[/snapback]</div>that answer was for you too Alton.
yea it doesnt look that bad of a swap at all ...thats the way we will be going with mine...
