Results 1 to 4 of 4
Thread: 15 Inch Truck Rims
    Dec 2005
    Hey I have a set of BFG 275/60/15 Comp T/A Drag Radials and my truck has 16 inch rims stock. (1999 Silverado) I am just wondering what year of trucks came with 15's that will work on my truck. I just want to buy some cheap "stock" rims to put the DR's on. Thanks!
    http://i76.photobucket.com/albums/j1...o/789547ee.jpg
    1999 Silverado LS RCSB 5.3 Liter (16.02@83.5 bone stock) (with mods ??.?? @ ?)
    STS Turbo Kit (5 psi), GT67, STS Intercooler, 42lb/hrs, 255 Pump, 212 216 Comp Cam, Nelson STREET Tuned, Eaton LSD, 4.11's, Phoenix ReTrans Stage 3 4L60E, 160 t-stat, B&M Supercooler.
    Oct 2005
    Baton Rouge, LA
    Aww, damn! Thought you were tryin' to sell. I was gonna be all over dat!
    My '86 came with 15s, but I know your bolt pattern (size & all) is different from mine. If no one here can tell ya, check with a local GM Parts shop. It'll take some looking, but they have that info (wheel size & bolt pattern based on year/make/model).
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(1BADC10 &#064; Apr 10 2006, 04&#58;10 PM) [snapback]49799[/snapback]</div>
    Aww, damn&#33; Thought you were tryin&#39; to sell. I was gonna be all over dat&#33;
    My &#39;86 came with 15s, but I know your bolt pattern (size & all) is different from mine. If no one here can tell ya, check with a local GM Parts shop. It&#39;ll take some looking, but they have that info (wheel size & bolt pattern based on year/make/model).
    If a 15 inch wheel will clear your rear caliper try an old 4x4 six lug wheel, i have a set here you could try if you were closer.
    Dec 2005
    I didn&#39;t even think of the caliper issue, but i guess i just assumed the rear brakes wouldn&#39;t be that big. I&#39;m just trying to keep from buying new tires. I have a mustang, (ya i said mustang) that i use the 15&#39;s on and i just thought i&#39;d swap them over since i have a tire machine here at the shop. Thanks i&#39;ll look for some old 4x4 one&#39;s if no one else has ideas.
    STS Turbo Kit (5 psi), GT67, STS Intercooler, 42lb/hrs, 255 Pump, 212 216 Comp Cam, Nelson STREET Tuned, Eaton LSD, 4.11&#39;s, Phoenix ReTrans Stage 3 4L60E, 160 t-stat, B&M Supercooler.
