Results 1 to 10 of 21
Thread: I smell 12's
    Apr 2005
    belton, tx
    Allen spent most of the day Monday street tuning my truck. A/F is near perfect, Timing is good. Only problem is my injectors are maxed (43lb). Boost is set @8 psi and I am positive it is much stronger than before. Almost wrecked on the highway home when it boosted me sideways @ 70 mph (wet road). It's scary quick to redline (p&p heads helped a lot). Will be ordering the 68 lb injectors soon!!! Want 12-14 psi.
    Trying to dyno tomorrow at a local shop here. BTW he's thinking of putting a dyno day together (Belton, TX-central TX) anyone interested?
    2013 2wd Z71 6.2 crew cab
    Old Truck: '04 Chevy crew cab stroked/bored 6.0 to 408ci. forged internals, patriot 68cc stage 3 heads (11.1:1cr), comp 244/246 .600 115lsa cam, 3000 yank tc, built 4L60E, walbro 255, 60# mototron injectors, pacesetter lt's 4" single no-cat exhaust
    best time 12.93 1/4 mi @ 103 in the turbo truck.
    1968 Camaro Convertible, super sweet!
    Jan 2005
    Conway, AR
    Sounds awesome man, glad you got that beast finally running! It hurts to drive around when you damn well know it has more in it doesnt it!?
    Chris
    San Antonio, TX
    Tell me you're going to take it easy on that beast, lol!!!
    Sorry we couldn't tune it to it's fullest potential, but we'll get there.
    Once you come back, you'll probably have the wideband installed. Expect it to run on the rich side on the dyno, but that was on purpose until we do a final tune.
    Once the 68's get in there, you'll be able to up the boost up and run very strong.
    The truck pulled very hard, 6200rpms came quickly and felt like it needed to be raised, but that's later on.
    Take it easy on it, hahaha, I know you're anxious, it's strong, but the truck will run out of fuel on the top end. Quick spurts will be fine, just no 1/4 mile runs, doh!
    nice seeing you again and let me know when you can come back down.
    allen
    Nov 2005
    SWEET!! Get the 68lb's in and lets go eat up some vett's!!!
    SOON TO COME!!!!
    Oct 2005
    Houston, Tx
    man !! now you truly have an SS. your truck actually deserves to wear those double Ss.
    Apr 2005
    <div class='quotetop'>QUOTE(stssilverado &#064; Mar 28 2006, 09&#58;21 PM) [snapback]48580[/snapback]</div>
    Only problem is my injectors are maxed (43lb). Will be ordering the 68 lb injectors soon&#33;&#33;&#33; Want 12-14 psi.
    Trying to dyno tomorrow at a local shop here. BTW he&#39;s thinking of putting a dyno day together (Belton, TX-central TX) anyone interested?
    You & I are in the same boat, 68 lbers for me too&#33;&#33;
    When would the dyno day be, I am in Georgetown, so that is a quick trip. No offense Allen&#33;&#33;
    I need a new cam too.
    Gone, but not forgotten!
    San Marcos Texas
    <div class='quotetop'>QUOTE(SCIV &#064; Mar 29 2006, 11&#58;19 AM) [snapback]48614[/snapback]</div>
    Same here&#33;
    i need an ls1
    Aug 2005
    Hey Guy, good luck with hitting your numbers. I am probably near my injector limits. I would be interested in knowing about your quest for 68# injectors and how it works out.
    03 Chevy ECSB, Z71, 6.0L(LQ4), Maggie @ 9PSI, 4l80E, PI Vig 2800, Detroit True-Trac, 4.10, 90mm LS2 TB, Meth Injection, HSW Dry N20, LPE GT7 Cam, 918 springs, Dynatech LT's, Hi Flow cats, custom stainless exhaust, DMH cutouts, DJM Suspension Drop, E-Fans, AirAid, HPT 2Bar SD Tuned, 11.68 @ 114.2
    Apr 2005
    belton, tx
    apprently injectors are easy to find. Need to change out the "clips" to LS1 style. Will let you know.
    My trans is now showing "transmission hot" message on the dash. Is it going out or do i just need an additional cooler. It comes on after i&#39;ve been pounding on it for a while.
