All the mounts worked out jut right. My factory driveshaft is perfect with the new motor mount positions. Minor fabrications to the trans crossmember and it will be done. Now its time to cut/box/weld/grind/paint/sitbackandsmile!! the frame and crossmember. All for a/c clearance. Then set her back in.
