Results 1 to 10 of 10
Thread: Fuel trims whacked at WOT
    Ok, tuning guys. Im no expert here but im stuck. I keep reading of the 5 and -5 rule for the LTFT's. But at WOT my LT's shoot to a positive 22. Which to my knowledge is indicative of a lean condition or the PCM trying to compensate 22% fuel. What do I need to do or look at to get the trims to zero like they should be? Or is it a better idea to skip watching the trims and pay attention to my wideband??
    -Jared
    Oct 2003
    TeXas
    did you plug the hole going to the t/b? I told you they were going to be all feckup lol.
    http://i17.photobucket.com/albums/b9...5831PM-2-1.jpg <--- TimeSlip
    RCSB 5.3 N/A 12.31 full boltons,H/C,4.10s,3800 converter. SOLD
    04 GTO
    Both Tuned By: ME
    <div class='quotetop'>QUOTE(vv8 &#064; Mar 19 2006, 09&#58;13 AM) [snapback]47384[/snapback]</div>
    They were all fucked up before that man. After this breather deal, they are still the same.
    -Jared
    At wide open throttle you should not see LTFT&#39;s or STFT&#39;s. They should quit reading around 4000 rpm or about 65% Throttle. That is where PE takes over. Your LTFT&#39;s and STFT&#39;s should go to zero across the board when PE takes over.
    2004 Nekkid Z71 Avalanche with increased traction, enhance aerodynamics, and upgraded airflow.....
    Jan 2005
    Conway, AR
    not true, you can see LTFT at WOT. STFTs are shut off at WOT, but only positive Ltrims show. I would see what your wideband shows, thats going to give you the real story.
    Chris
    <div class='quotetop'>QUOTE(chrisj6 &#064; Mar 19 2006, 08&#58;17 PM) [snapback]47429[/snapback]</div>
    Chris
    H-m-m-m-m Every time I go WOT my LTFT&#39;s and STFT&#39;s go zero across the board and my histograms show zeros in both tables. That one of the indicators I used to watch the spray on my meth. I guess you are telling me my LTFT&#39;s are probably negative? If so I just learned something. Guess I can call it a day.....
    Jan 2005
    Conway, AR
    Yeah I have had many scans show +1 and +2 on WOT, your trims are either negative or dead on 0, which is a good bet if you have a Nelson tune, I never saw many +trims on mine&#33; Now me trying to tune on my own on the other hand, I&#39;ve seen my share of positive trims&#33; The pcm adds the positive trims just for a safety measure.
    Chris
    Jun 2005
    I always thought the STFT went to zero above 4000 rpms and the LTFT held steady. LTFT are only updated every 10 minutes from the STFT&#33;&#33;&#33;&#33;
    Jan 2005
    Conway, AR
    ohhh LTFT are updated much more frequently than 10 mins&#33; Have you set your histogram to last value lately and watched how frequently they change?
    Chris
    Feb 2005
    <div class='quotetop'>QUOTE(99Silver5.3 &#064; Mar 19 2006, 01&#58;34 AM) [snapback]47375[/snapback]</div>
    Ok, tuning guys. Im no expert here but im stuck. I keep reading of the 5 and -5 rule for the LTFT&#39;s. But at WOT my LT&#39;s shoot to a positive 22. Which to my knowledge is indicative of a lean condition or the PCM trying to compensate 22% fuel. What do I need to do or look at to get the trims to zero like they should be? Or is it a better idea to skip watching the trims and pay attention to my wideband??
    What is your WB reading?
    I had a similar problem where I was reading very positive LTFTs all of a sudden. It turned out to be my scanner config file was corrupt. I created a new one and viola, it was working normal again.
    Edit; Opps just noticed this is like 2 months old. lol
    New Truck on it&#39;s way: &#39;07 Classic GMC 2500HD DuraMax LBZ
    03&#39; Silverado ECSB 4x4 Z71 LQ9, TR230, Patriot LS6, 31lbs, Trailblazer stall, Corvette servo, Corsa Touring,
    HP Tuners
    SOLD - 99&#39; Silverado ECSB 4x4 5.3, Edelbrock RPM, Nitto Terra Grapplers, Texas-Speed Tuned 02&#39; PCM, LT1 fans
