[attachmentid=511]
I have a pair of Edelbrock IAS #34023 shocks for sale. They are brand new, still in the original boxes. My order got duplicated, and I held on to them. They are for a 4" rear drop. First $100 + shipping gets them both. The following is from truckperformance.com:
EDELBROCK Rear Performer IASŪ MonoTube Shock
Part Number: 34023
Retail Price: 97.95
Your Low Price: 72.77
Drive Type: 2wd
Note: Fits Vehicles Lowered 2in Front x 4in Rear
Information
Edelbrock IAS shocks deliver incredibly responsive handling around tight turns and dramatically reduce body roll with a comfortable ride for outstanding vehicle control. Manufactured by Edelbrock in the USA, these are the only automotive shocks that incorporate the patented Ricor Inertia Active System. This unique valve design senses changes in terrain and adjusts instantly for a better ride than you ever thought possible. Performer IASŪ Mono Tube Shocks use the patented Inertia Active System to automatically adapt between a soft or firm setting depending on driving conditions for superior handling and a smooth ride. Adjustable ride height coil over shock allows for 1.5 inch lowering. Keeps tires on the road, reduces chassis roll, and improves stability and handling.
Maximum Handling And Maximum Comfort For The Best Of Both Worlds In Suspension Performance!
Large 46mm Piston for More Consistent Damping!
High Pressure Gas Mono Tube Design Provides Excellent Heat Dissipation Resulting In Consistent Performance Under All Conditions!
Viton Seal And Low Friction Piston Rod Bearing For Long Life And No Leaks!
Dramatically Reduces Chassis Roll For A Major Improvement In Stability!
30-Day Money Back Guarantee!
Faster And More Precise Than Computerized Shock Systems!
Limited Lifetime Warranty!
Installation: Installs exactly like a stock shock. Polyurethane bushings and shock boots are included.
2000 ProCharged Silverado
11.94 @ 111.62
"I never met a pound of boost I didn't like."
~ Jeff Harris / Mo's Speed Shop - Dallas, GA
- You may not post replies
- You may not edit your posts
