You guys can see the setup below. Had read on the web (after-the-fact) that someone had read Powertraxx doesn't do well around 400hp. Well, I think I can put that theory to rest.
I had thought the problem this whole time was with the driveshaft/carrier bearing/axle. Well...guess what remained intact, but ruined the ring-pinion? It broke off two teeth, then skipped a few and broke one more off. Apparently one got thrown into the heavy duty differential cover I had and cracked it all the way through
So, what do I replace it with - Auburn or Eaton? Another?
I'm going back with the 3.73s and the posi and a new heavy duty cover.
93 Ext Cab w/ 99' LS1, AFR 205cc heads milled to 59cc, G5X2 cam (232/240 .595/.608@114LSA), Edel LS1 headers, 6.0L intake
Edel IAS shocks, Hotchkis front/rear antisway bars, 3.73 Axle w/ 8.5" -10-bolt w/ Eaton Posi
