Results 1 to 4 of 4
Thread: My sister needs some help!!!
    May 2004
    Hey guys my sister is out of state and she has a 02 trailblazer that the right rear window is stuck down. She has it at a local shop and the manager says it needs a master switch assm. in the drivers door(easy enough to understand) heres the rub..... says has has to take it to the dealer to get programed for an addiotional 100.00 bucks..... I smell a rat.. anyone know anything about this????? thanks Doug
    04 Silverado SS with livernois 67mm hybrid, 60 lb injectors. PKRE Special grind cam, Meth. Nelson tune, 3500 yank, built 65e 3'' 5'' drop, 20" Centerline Stingrays.......... pretty fast for a "shop truck"
    Dec 2003
    Does it make any noise at all like it's trying to go up? If it is, I definately call boolshit! My brother had trouble on a driver's side window. When the stealership replaced the regulator it worked fine but the passenger's side stopped working. They told him they'd have to replace a bunch of crap and it started working fine when he got home. Must have just had a loose connection when they hooked up the window panel switch again.
    2003 Arrival Blue Silverado SS.....I just can't leave $hit alone.
    May 2004
    I don't think that it's a reg from what she's telling me I just don't get the programed B.S. for a simple combo switch...
    Dec 2005
    Dallas, TX
    My buddy had that prob but that was cause he had that alarm that rolled down the windows. it cut the power of so it wouldnt let it role up. i think is bs too. Does she have someone to check it out, like that can jump wires to make sure that its just the switch?
    2001 GMC Sierra C3 with the 6.0! Vararam King Cobra, TB bypass, No cats with two 3 inch cut outs and thats it for the motor. FOR NOW ATLEAST!!
    9.5 in the 8 mile
    6000K xrtalight h.i.d kit
