i installed my shorties, and bolted rigt up will i need to cut pipe or flange to make them fit any advice
99 ECSB 5.3 LS6 CAM AND SOME BOLT-ONS BEST TIME 13.6@97MPH
http://i104.photobucket.com/albums/m...wTRUCKS008.jpg
Shorties are made to bolt right in place of the factory manifolds.
<div class='quotetop'>QUOTE(1slow01z71 @ Feb 8 2006, 11:50 PM) [snapback]44010[/snapback]</div>so what would need to be doneShorties are made to bolt right in place of the factory manifolds.
Oh you are talking about installing lt headers in place of your shorties? If so then you need to have the y-pipe modified to attach to the collectors of the lt headers.
what LT's did you buy? pacesetter has a y pipe for theirs, but all others you need to cut and weld
04 ECSB Silverado 4X4
Nelson Tuned - 220cam - 3000yank stall - stage 1 heads
LS1 fans - ASP pulley - 3inch lift - ASM LT headers Mod Page
aka 98TAauto - 98TA 11.4 @ 119 H/C street trim
Take your truck over to Deer Park Muffler and ask for Mark the owner. He'll build your "Y" pipe and save you money.
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
<div class='quotetop'>QUOTE(04Grill @ Feb 9 2006, 09:37 AM) [snapback]44023[/snapback]</div>what LT's did you buy? pacesetter has a y pipe for theirs, but all others you need to cut and weld
Dynatech (SuperMaxx) LT's also can be bought with y-pipe that bolts right in.
03 Chevy ECSB, Z71, 6.0L(LQ4), Maggie @ 9PSI, 4l80E, PI Vig 2800, Detroit True-Trac, 4.10, 90mm LS2 TB, Meth Injection, HSW Dry N20, LPE GT7 Cam, 918 springs, Dynatech LT's, Hi Flow cats, custom stainless exhaust, DMH cutouts, DJM Suspension Drop, E-Fans, AirAid, HPT 2Bar SD Tuned, 11.68 @ 114.2
DeerPark Muffler I know wher that is off Center St. how much ya think he 'll charge
<div class='quotetop'>QUOTE(04Grill @ Feb 9 2006, 08:37 AM) [snapback]44023[/snapback]</div>they are pacestter i didnt know it was needed saw it for $129what LT's did you buy? pacesetter has a y pipe for theirs, but all others you need to cut and weld
I bet he would charge 100 to do it. Whenever he tells you a price you can talk him down some still. I learned that the hard way after over paying for a while and argued with him on the price he dropped it down some. They do good work.
Take cash and go on an early Saturday morning if you know what I mean.
97 GMC, 2002 LS6.
