Results 1 to 3 of 3
Thread: Good cam for 6.0?
    Apr 2004
    okay i have been planing on doing a 6.0 swap into a S-10, and want a cam that will pull though out the whole RPM band, i am thanking a 224/224 on 114, and would i need a tune or stall with that cam? i just want to stick wiht stock heads for now, so what kinda #'s could i Expect with that cam on stock heads and a good free flowing exuast and maybe a tune?
    San Antonio, TX
    <div class='quotetop'>QUOTE(sr_ryan1 &#064; Jan 23 2006, 05&#58;44 AM) [snapback]41909[/snapback]</div>
    okay i have been planing on doing a 6.0 swap into a S-10, and want a cam that will pull though out the whole RPM band, i am thanking a 224/224 on 114, and would i need a tune or stall with that cam? i just want to stick wiht stock heads for now, so what kinda #&#39;s could i Expect with that cam on stock heads and a good free flowing exuast and maybe a tune?
    What gears, tires, trans do you have?
    The 224 is a nice cam and will pull great from 2800rpms to 6500rpms.
    To take advantage of the cam, you&#39;ll definitely need a tune. If not, your truck will be shifting at the stock rpms, idle will be fussy, and the truck will down on power.
    Plus, you&#39;ll need a tune to take care of vats, accessories, etc.
    Expect about 50hp at the flywheel from that cam in a stock 6L.
    good luck,
    allen
    Apr 2004
    <div class='quotetop'>QUOTE(farmtruc &#064; Jan 25 2006, 10&#58;15 PM) [snapback]42288[/snapback]</div>
    good luck,
    allen
    3.72 gears, and built 4L60E. Could you do a tune for me if i send you the PCM?
