Results 1 to 3 of 3
Thread: Service 4WD Drive Light?
    Jul 2005
    Loganville, GA
    My service 4WD light came on today when i was ridin around and i talked to some buddies that work at a local dealership for a sec and they said it could either be the 4WD switch or he transfer case control module maybe so i dk i was just seeing if anyone else had the problem or knows anything else about it, any help would be appriciated.
    thanks
    1999 GMC Sierra Z71 Ext Cab, True Dual Flowmasters with X-Pipe, True Flow Intake, MSD 8.5 Superconductor wires, 180 Thermo, TB Bypass, Optima Battery, Synthetic All the way around
    http://i139.photobucket.com/albums/q...7787/Truck.jpg
    Apr 2005
    <div class='quotetop'>QUOTE(Z71sierra7787 &#064; Jan 18 2006, 05&#58;00 PM) [snapback]41397[/snapback]</div>
    thanks
    prob the 4wd switch .. it happened to me .. the lights would dim and the 4wd wouldnt work sometimes
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
    Jan 2005
    Conway, AR
    replace the switch first, happened to my cousin, then again right after the switch went the transfer case, so could be either.
    Chris
