I'm in the process of installing a intercooled Whipple 3300AX supercharger on my Tahoe.My problem is I need to upgrade my fuel system to properly feel the new system.My current fuel system consists of the stock fuel pump with a Edelbrock#1794 inline fuel pump using the Radix modified stock fuel regulator feeding 57lb injectors.I plan to keep the 57lb injectors,but I need to run them at 60lbs of fuel pressure with a boost referenced regulator so I will need at least 85lbs of unregulated fuel pressure to maintain the proper pressure at boost.I also need to provide enough fuel volume to maintain a 10.5 to 1 AFR at 1567cfm max airflow.I'd also would like to keep my stock fuel tank and keep an operational fuel guage.Does anyone have any suggestions or know of someone who can build me a fuel system that can do the job. Thanks Whitt1
